Question about Linksys EtherFast Cable/DSL Router
Losing Ports on Linksys BEFSR41 v.3
Every so often, I lose ports 2-4 on this router. Port 1 seems to be reliable. I have the latest firmware (1.05). I have reset and loaded default, still have intermittent problem, though when I plug and unplug it works fine until it happens again.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Try a different wall plug power supply. The power supply that comes with this unit is very unreliable and unstable when loaded.
Posted on Jan 17, 2009
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Hardwire ports on wireless router not working
You could
1) Reset the router to factory default by hitting the reset on back
2) You could visit the router over the wireless link (http://192.168.1.1) default password is "admin" username blank.
Check on the page to ensure the ports are enabled.
3) Update the firmware on the device. see if it works.
Note there is a port called "uplink" which is designed for the internet connection and not the local computer.
Jul 22, 2010 | Linksys Wireless-G WRT54G Router
Ps 3 linksys 160n problem
Hi Friend,
In order to use PS3 we need to open few ports. Kindly follow the steps:
1.Open the internet explorer and type 192.168.1.1 and hit enter.
2. If you have not changed the default password of the router then kindly leave blank the username box and in the password box type admin and hot enter.
3.In the setup page click Application and Gaming
4. Under that click Port Range Forwarding.
Below are the port numbers which we need to open for PS3
TCP:
80
443
5223
UDP:
3478
3479
3658
Now please type these port number in start and end port. Please make sure start and end port has to be the same.
First enter the TCP ports in first three boxes and then UDP ports in next three boxes.
Save the settings and turn off the router for 10 seconds and restart again.
Enjoy.
Regards
Chiranjeet
Mar 15, 2010 | Linksys WRT160N Wireless Router
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Oct 13, 2009 | Linksys WRT160N Wireless Router
Linksys wireless g broadband router begins flashing 2 ethernet ports simultaneously and consequently internet unavailable. Tried moving cables around between the three available ports and the same thing...
Hi
Dont think that the router is dead
1.Make a hard reset
2.Reconfigure
3.Install the latest version of firmware
That should definately sort the problem out and do let me know
Mar 10, 2009 | Linksys Wireless-G Broadband Router
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys EtherFast Cable/DSL Router Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
