Question about Dryers
Dryer runs intermittently
Recently we had a water problem in our laundry room which resulted from a drain clog. Water backed up in the drain and gushed out behind the washer and dryer onto the floor to a depth of maybe 1/4 to 1/2 inch. The water likely splashed onto the back of the dryer and washer also. After cleaning up the water on the floor, and throwing some very wet towels in the dryer, I pushed the dryer's on button and the dryer started but then almost immediately shut down. I could find not find a "reset" button anywhere on the dryer and have tried various "tricks" to restart it since then, e.g., turn the time knob clockwise 2 or 3 times, unplug and replug the dryer's electric cord. The first time I unplugged the dryer, I noticed that the plug looked like it was somewhat scorched. I have also noticed an "electrical" smell on occasion when the dryer is actually working. I have been able to dry a couple loads of clothes but the most recent use resulted in a very strong "electrical burning smell" and I have not used it since. I removed the small access panel where the electrical cord goes into the back of the dryer but did not see any signs of shorting at the terminal. Could the cord/plug and/or receptical be bad and need replaced or is it likely to be something in the dryer's internal wiring?
  • slpurcell1 Dec 21, 2008
    Thanks for your prompt reply rpbuice. After I posted the above help request, I disconnected the flexible 6 or 7 inch vent hose which exits the back of the dryer and found tons of lint in it. I removed what I could but think I'll buy a replacement hose. After removing the lint from the vent hose the dryer started right up but, after running for 10 or 15 minutes, I again noticed the same burning smell although now I'm not sure it's electrical. As you suggested, I'll get a replacement cord/plug, and vent hose and install them before I begin using the dryer again. If the burning smell persists after replacing those, I'm not sure what else to look for. Any other thoughts would be appreciated.
    Novelist:
  • 161 Answers
"Could the cord/plug and/or receptical be bad and need replaced or is it likely to be something in the dryer's internal wiring?"
Yes, that electrical smell and the dryer not working are all signs of a bad motor.
"I noticed that the plug looked like it was somewhat scorched."
I would replace that plug. This is how electrical fires start.
Posted on Dec 21, 2008
  • Ron Buice
    Ron Buice Dec 21, 2008
    The vent hose shouldn't be clogged like that, make sure the hose is not kinked real bad and you have good air flow on the outside.
    Since you have so much lint, I would clean the dryer on the inside especially around the heater coil. This may be lint you smell burning. You may have to call an appliance tech to take it apart and vaccum real good.
Sewage backing up into laundry room when we use our dishwasher. We have a septic tank. Both toilets flush fine, and no back up in tub
The drain leaving the laundry room going to the main needs to be cleaned. The first thing you can try is what is called a product called Drain King . This is connected to a garden hose and inserted into a drain where the p-trap is removed from the wall When the garden hose is turned on full blast it will try pushing out the clog You should hear it pulsate first slowly then more quickly as the clog is washed away.he water flowing with Finally you should hear water flowing freely. it helps to use warm water if possible. If that won't work the drain will need to be snaked , Turn off the hose and remove the Drain King by loosening the hose connection Then follow that pipe downhill toward the main drain, and look for a clean-out plug. You can loosen the plug SLOWLY, have a bucket, mop, and rags ready and wear old clothes. Place the bucket under the clean-out plug if possible while slowly removing it Water will come out unless the clog is between the laundry sink and the clean-out. If water comes out when the clean-out plug is removed place your snake drain cleaning device into the clean-out and run until the clog is cleared. then run water through it for a while to wash away any residual residue. Put everything back together and test for leaks.
Jul 30, 2014 | Home
Hi I have a problem with my laundry machine.Its flooded and the water stays in the laundry machine and the water wouldn`t go away.We washed our clothes with three programs in a roll.And maybe thats the...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Aug 08, 2011 | Washing Machines
I have a Roper Washer Model # AL4132VW1 while doing a load of laundry yesterday my washer wouldn't remove the water. I tried all the cycles but it still wouldn't work. Do you have a idea what is...
Jul 25, 2011 | Roper Washing Machines
Laundry room flooded
could be as simple as a blown thermal fuse.  most places will allow credit for a service call toward purchase of a new machine if repairs are too costly
Jul 28, 2010 | Kenmore 65924 Electric Dryer
Water comes into machine when on dryer clothes tak forever to dry
This machine drys by intermittently spraying a mist of cold water into the warm, moisture laden air traveling in the tube at the back right side of the machine. The cooling of that air stream causes moisture to condense and join the added water, which is periodically pumped out the drain. It takes a long time, and the clothes are not as "dry" as you may be use to with a conventional dryer. Never try to dry more than a half tub of laundry. These machines are great if you have small amounts of laundry to do, have limited space, and / or do not have 240 volts, (or a gas supply) and cannot do an outside vent. Don't plan on doing more than two loads per day. (one in AM, one in PM) Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Jan 17, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dishwasher
Dishwasher: I'm assuming you are talking about when the dishwasher is not running. Correct? If the dishwasher accumulates water while sitting idle, it could be a couple of things. The water inlet valve could be leaking by, or you may have an improperly installed drain line. If you do not have a high loop in the drain line, water can back feed into the dishwasher when you drain your sink. Some dishwashers have a check valve on the drain line to prevent this.
Dryer: Dryer times will vary depending on the load size and type of clothing. Properly sort laundry to make sure lighter materials are separated from denser clothing that holds moisture. For example, if you attempt to dry jeans or towels with light cottons or linens, the moisture from the denser material will transfer to the lighter material. This can cause longer dry times. Towels and/or jeans should be dried on a hotter temperature setting - usually takes 30 to 45 minutes. Cottons and linens will take about 30 minutes on a lower heat setting. Make sure the dryer exhaust vent is not clogged. If the dryer cannot exhaust properly, the dryer heating circuits will actually overheat and eventually fail. The result is a hot dryer with clothes that will not dry. If you suspect you have a dryer vent problem, remove the vent hose from the back of the dryer and try drying a load. If your drying results improve, you probably have a clog in the dryer vent EXTERNAL to the dryer. If the results are the same, inspect the dryer INTERIOR. NOTE: Rule of Thumb - The SHORTER and STRAIGHTER the dryer vent, the better. Dryer vents that are excessively long, have many bends, or run through an attic or crawl space are the worst for accumulating lint. Also DO NOT push the dryer all the way up against the wall. This tends to crush the exhaust vent hose. Leave about a one foot space between the back of the dryer and the wall and use the semi-rigid metal type dryer vent hose. It resists crushing and rodents from chewing through it.
If you would post brand name and model numbers of your appliances in the future, it would make it much easier to diagnose a cause and be able to tell how the appliance is configured. I hope you find this information helpful.
Jun 21, 2008 | Kenmore 15129 Built-in Dishwasher
Water comes out bottom when I run multiple loads
pull the dryer and check your venting you can remove the vent and run a load to see if it works ok i know the hot air will come into the room but it is just a test to see if the vent is clogged this is where the condensation would come from chweck that and let me know
Mar 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer problem
Your problem may be associated with heavy accumulations of lint inside the dryer and/or ducting. If you have had a water leak recently, and the dryer ducting got wet, the lint could be sticking somewhere and forming a clog. A simple way you can determine if you have a clog somewhere is to disconnect the dryer vent hose from the dryer and start the dryer. The air leaving the dryer should be forceful and about 140 degrees (in other words...good and warm). If the air is weak and cool, you have a clog somehwere INTERNAL to the dryer. If the air is forceful and warm, check your ducting from the dryer to where it exits the house. A dryer needs proper air flow in order to dry properly. The fact that your dryer is getting very hot tells me that the heating element is heating up, but may in fact, be OVERHEATING. The dryer will not continue to run in this condition. Eventually the heating element or thermal fuse will blow. Take the time to perform these simple steps and post back with your results and/or comments. If it is not a simple clog, I can give you further advice on how to determine a cause of your problem.
NOTE: If you plan on cleaning the dryer interior, ensure you unplug the dryer from the power source. Live voltages of 220VAC are still present even with the dryer turned off.
Jan 14, 2008 | Amana NDE2335AY Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Marvin
Marvin
