Question about MPC Computers Envision EN 5100e 15" Flat Panel LCD Monitor
Envision LCD monitor: ''Auto Config Please Wait'' is always on
I have an Envision model EN-LM500 LCD monitor (product EN-5100e). For the last couple of years it has been occasionally going blank for half a second and then immediately comes back. It wasn't bad enough to do anything about it. Now, when it goes blank or starts up, I often get a permanent window in the center of the screen that says ''Auto Config Please Wait''. It's happening more and more often now. With that window in the center of the screen, it's not usable because it covers every other window. Is there anything I can do to fix it?
Thanks.
Just tell me why this message comes up and if it means my monitor is going
Posted on Jan 23, 2009
I keep getting a flashing message, "Auto Config Please Wait" It never stops what can I do to fix it ?
lower your resolution on your computer. Sounds like a resolution conflict there somewhere. Also try reloading your video card drivers.
Aug 12, 2014 | Envision Computers & Internet
Mijn beeldscherm blijft steeds auto config
Elke monitor heeft een menu-optie. Zoek met uw handleiding hoe u uw menu-opties voor uw specifieke model en daar toegang te krijgen is een optie om berichten of waarschuwingen weer te geven. U **** het uit daar.
Jun 20, 2012 | Acer LCD Monitor P193W
Envision monitor EN-7100e color is screwd up.
Unfortunately this monitor has captived VGA cable, you cannot easily replace it. Try moving the cable around to see if you will get normal color back.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001218.pdf
http://s807.photobucket.com/home/budm/allalbums
Apr 12, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Bluish screen -
is it a greenish blue?..... if so you have lost your red signal..... check your monitor connectors for bent or broken pins...... usually happens after swapping cables or monitors on a computer..... you could also have a bad cable or monitor..... is the monitor a CRT or a flat panel.... loss of one color is very common on CRT monitors, and could be a bad solder connection on the CRT driver board, or a bad video chip..... flat panel LCD monitors don't usually lose a color, although it is possible.... the most common failures on LCD flat panels is total power supply failure (no power at all) or display matrix driver failure (colored stripes across or down the screen), but a cable failure is also possible, like i said above, check the connectors for bent or broken pins..... there are 3 rows of pins...... at the widest side of the connector, there should be at least 3 pins next to each other on that row (sometimes there are 5), the middle row should at least have 3 consecutive pins as well (and again, there are sometimes 5) the last row (the smaller side of the connector) should have at least two (but sometimes all 5) pins in it. the first row and last row of pins should line up vertically, and the middle row is offset a half a space, so from top to bottom, the columns of pins make a zigzag...... if the connectors are alright, then your most likely problem is the monitor..... if another monitor works on the computer, it's the monitor..... if another monitor has the same problem on this computer, then it is the video card (or the motherboard's video output, which is fixable by installing a video card)
Jul 26, 2006 | MPC Computers Envision EN 5100e 15" Flat...
MPC Computers Envision EN 5100e 15" Flat Panel LCD Monitor Logo
483 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Joe Goldman
Joe Goldman
Josh Levin
Josh Levin
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
