Question about Sharp AR-5316 Advanced Digital Imager Copier
I send a printing but the machine showing me 4 and H on the screen blinking in green colour
    President:
  • Sharp Master
  • 990 Answers
DEAR SIR; The H-4 code means heat unit not function property, but I can reset it for you just follow my steps;
1, press"#", "interupt", "c", "interupt" machine will go dead.
2, enter 14, then press start key.
3, press "clear" key to end of simulation.
now you can your machine back to work, if you need more help please email me, I'm always around but don't forget give me a rating, good luck, HAVE A HAPPY HOLIDAY !!!
Posted on Dec 22, 2008
My yellows ansd greens are switched
there are a number of possible errors here.
have the machine align its printheads
then have the machine complete colour calibration ( you will need good working printheads to complete the calibrations
when this is finished have the machine print out its config pages and demo print page ( you can find how to do this in the online user manual) this is done to Isolate the printer from the fault - if The demo page and config pages are printed correctly then the error lies external to the printer ( the software printing the document)
OR
check to see if the correct printer driver is installed (to be sure uninstall then re-install) open the driver and check to see in Preferences/colour that the settings are 'let machine decide colours'
or set to adobe pdf. print out the test page from the driver and pay close attention to the windows logo at the top of the page- it should match that on the windows start screen
if you can see that the green yellows are still out of calibration then you may need to change the printheads ( CYAN/Yellow) as the error may lie internal to the printhead.
at the end of the day the fault lies most likely with the software setup or the printheads.
Jan 18, 2014 | HP Officejet Pro L7480 All-in-One...
Saeco Philips coffee machine display screen doesn't light up? I can still use it and I can see the options but with no colours.
I can still use it and I can barely see the options but display screen doesn't light up
I'm having it sent back for repairs, is there a quick fix for this issue so I do not have to send it back
Apr 11, 2013 | Saeco Intelia Focus Automatic Espresso...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
I have a HP OfficeJet G85 all in one machine. Just changed the colour cartridge for a HP original one. First alignment page was good showed all colours. The first time i used it it would not print red it...
Have you any applications like deep freeze installed on your computer machine? If so uninstall it restart your computer and try to print again. The fact is some programs cause colour malfunction in the computer. The similar scenario I encountered, I had to format the system for the colours to print correctly again. But i have seen where deep freeze cause similar issues before.
Good luck & God bless!
Feb 11, 2011 | HP DeskJet F380 All-In-One Printer
Wrong colour
Have you done the nozzle check print? It would show if any colors are missing. While ready with the green light on, press and hold the resume button until the green light flashes twice and release, it will print the nozzle check. You also can't use the photo magenta or photo cyan in this machine, you need the regular cartridges.
Oct 08, 2009 | Canon BubbleJet i550 InkJet Printer
Print text is grey not black
Have you tried cleaning the laser? Open the front door, on the R/H side there is a green lever, pull this forwards. Next on the R/H side of the printer pull off the small panel, inside is a green handle. Pull this in & out fully a couple of times to clean the laser lens. Hopefully your prints will now be back to normal. If not then there could be a problem with eitherthe black developer or the PCU. Try printing some horizontal coloured bars to see if all of the colours are affected or just the black.
Mar 16, 2009 | Epson Aculaser C1100 Printer
Hp psc 1210 all in one colour problem
The cartridge may be defective. I had that happen so I returned for another and it worked fine
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Jun 26, 2008 | Office Equipment & Supplies
Sounds like Color cartridge problem...
Colors on the cartridge are mixed together
Dec 05, 2007 | HP PSC 1210 All-In-One InkJet Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
