Question about Hitachi 36FX49B 36" TV
Vertical problem I own a Hitachi 36fx49b t.v. set. Recently the t.v. has a horizontal, bright line through the middle of the screen and no picture. The set is too old to hire a t.v. repairman so I would appreciate any input or solution that a knowledgeable do-it-yourselfer, like me, could use, to fix the problem.
  • joel mcmackin Apr 07, 2007
    Pravin, Obviously if I knew solid state electronics I would be a t.v. repairman myself. What i do know is economics, and it doesn't make any sense to pay someone more than the set is worth to replace it. Therefore, if you would like to be helpful try telling me where this vertical output oscillator can be found inside the t.v., and how to replace it. Thank You.
    p.s. another thing I know is how to spell "know".
    Novelist:
    Champion:
  • 275 Answers
Joel, you may be a knowledgeable do-it-yourselfer, but do you know solid stae Electronics servicing. From the description of your problem, it looks like the Vertcal oscillator / output IC has failed. If you knoe S S Electronics, replace.
Posted on Apr 06, 2007
  • Pravin Gupta Apr 17, 2007
    Glad to know that you can spell 'know' well. Only thing is, i see reason for you to take umbrage at my statements. It is not neccesary that all people who know solid State Electronics end up as TV technicians. there are hobbyists who do have the knowledge, and that was the focus of my comment.
    It was in good faith, and with every good intention.
    I will give you the part no. for the set tommorow, after i have studied its Schematics.
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Nov 26, 2008 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
No Picture On Screen and red line in middle.
The set has a vertical problem if the line you mention is from side to side ,if the line is from top to bottom the problem is in the horizontal circuit and both can be repairable,a vertical fairlure is a common problem,the vertical IC goes bad and it takes a safety resistor with him to prevent any more damage,the horizontal is rare but it happens too,if you are familiar with tv service you can change the IC but you will need a service manual to identify the part,you can get a manual overnight if you downloaded it at www.servicemanuals.net,if you are not too familiar you should seek the help of a servicer for safety reasons.Let Us know how it goes or if you need more information.
Nov 01, 2006 | Hitachi 36UX01S 36" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Hitachi 36FX49B 36" TV Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
