Question about Microwave Ovens
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
Our Kenmore 721.80803401 is approximately 3 years old and has had the same problem from day one. The rotating/sliding table jumps up and completely disengages from the rotating arm. As some others have noted, the problem will come and go, sometimes occurring frequently and then will disappear for several weeks. I have completely removed/inspected the table assembly from the microwave but have not been able to identify any sticking/damaged parts. The only questionable thing I found was that the rotating arm would sometimes pop out of its center hole, completely disengaging from the internal rotating mechanism. This would definitely cause the table assembly to stop turning and drop out mechanical time with the motor. I have been carefully inspecting the arm to make sure it is inserted completely but the problem has still been occurring.
When the table assembly pops up, the cooking liquid will often spill all over the glass plate resulting in a big clean-up. Other times we will be out of the room and not notice that the rotating table has stopped and the food will not cook properly.
If anyone has solved this problem, please post the solution as I am just about frustrated to the point of replacing this microwave/range hood.
  • derajm Jan 17, 2009
    Since posting this problem on Dec. 21, 2008, I have been researching possible fixes. Several experts have suggested replacing the complete glass tray and rotating-arm assembly but paying 60 dollars plus shipping seemed to be a large investment for this three year old microwave. A diagram of the rotating arm, showed that it had been redesigned with an additional wheel which should prevent the rotating arm from disengaging from the slot in the bottom of the glass tray.
    RepairClinic.com offers the part (item #1327966 ring assembly) for 10 dollars plus 5 dollars shipping. I took a chance, replaced the part and bam! no more problems.
    Why does the consumer have to pay for the mistakes of the manufacturer? It's obvious that the manufacturer redesigned the complete assembly because of this reported problem.
    Another thing to keep in mind is that there may be more than one problem with the tray assembly and that is why the experts have suggested replacing the complete assembly. The good news for me is that the 10 dollar part fixed my problem.
    Guru's recommendation fixed my problem. Tritronics does offer the part but because it is not an in-stock item, it ends up costing twenty dollars plus. Also, the company does not post a picture of the new part which I wanted to see in order to determine if the part had been redesigned. RepairClinic.com has the part in stock (item #1327966 ring assembly) for 10 dollars with a picture included.
  • Microwave Ovens Master
  • 9,098 Answers
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Posted on Dec 21, 2008
I have a kenmore microwave toaster. Microwave no heat. table rotates OK and toaster works OK. What is most likely problem, HV diode, capacitor or magnetron?
Could be any of those 3 parts since they work together to make the microwave part work. Most common problem if under 5 years old would be the diode, then capacitor, then mag, but I have replaced mags on new microwave in some cases. Like I said they work together. Capacitors will sometimes swell up at the top or bottom but again not always.. This isn't much help but you need a multimeter and must know some test procedures on this one.
Apr 14, 2015 | Kenmore Microwave Ovens
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p][p]
Jul 07, 2010 | Kenmore 63663 Microwave Oven
Microwave does not heat food or liquid
I hate to tell you this but your magnetron may be shot. Its the part that actually makes the microwaves. The best thing I can recommend is get a new oven, magnetrons are expensive and not easy to replace.
Mar 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave rotating assembly jumps up and stops turning.
Dec 21, 2008 | Microwave Ovens
Carousel stopped turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Kenmore micowave oven over range
Usually this is due to your diodes going bad. I recommend replaceing the magnatron at the same time though.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Pop pop Kenmore hood microwave 665.60652 - year 2002
hmmmm, i wonder if you have a gear or something similiar to this going out. (turn tables)
If not, something tells me you have a component that is arching inside of your micrwave. I would call someone to double check to make sure it is ok.
You will be surprised at how many people wait until it is too late to service their units, when it goes out, it is gone.
good luck
May 25, 2008 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
512 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
