Question about Maytag PER5510 Performa Electric Kitchen Range
Range lock issue
Model #PER5510BAQ When I try to turn on "BAKE" the control panel shows "LOCK" is on. Would this possibly be the sensor/lock gone bad or maybe even the door latch switch?? The control panel seems to function just fine so maybe I can narrow it down to one of the two above. Does someone know with more certainty than I???
  • 1 more comment
  • WOODSAND May 17, 2008
    WHEN I TRY TO BAKE THE LOCK LIGHT FLASHES AND THE STOVE DOES NOT WORK I TRIED TO HOLD THE STOP TIME AND CANCEL BUTTON AT THE SAME TIME AND IT DID NOT WORK IT JUST SHOED OFF
  • tippin5 Aug 28, 2008
    My stove is responding Lock and I pushed Cancel and Stop Time for the 5 seconds. It went into Off mode. I did it again and it went back to Lock mode. what should I do?
  • psych350 Oct 13, 2008
    I'm having the same issue. When I do the suggested solution, it just goes to "off" and locks everything. I try again and back to the same issue. Ugh
    President:
  • 878 Answers
Rollover, press and hold the stop time and cancel keypads together for 5 seconds. See if it comes back to life...Catriver..post back.
Posted on Apr 21, 2007
Lock control #3 on Electrolux slide in range
I appreciate your post, Billy!
I understand that the lock control will not unlock on your Frigidaire range. I noticed that you have disconnected the electricity and the range is still not unlocking. I would recommend holding down the clear/cancel button for at least 15 seconds. If that does not unlock your range I would suggest that it could be a possible issue with your door lock or control panel. For any repairs to be completed I would recommend having a professional technician out to complete a diagnosis. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 08, 2015 | Electrolux Kitchen Ranges
A model KERH507YWHO Kitchenaid range is stuck showing F2 we were trying to clean the onen What do we need to do to get it going again? thank you
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Here is that part. Oven Control Assembly black
I don't believe that it is available any longer.
Nov 10, 2014 | Kitchen Ranges
I have a frigidaire gas range model FGF379WECG, the control panel say that my oven door is locked, but the door opens, when I turn on the oven to bake or broil the lock engages and disengages for about 30...
Good Afternoon Donna, thank you for your post!
Let's try resetting your range by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Is the unit still advising that the door is locked? An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the EOC (Electronic Oven Control) and door latch assembly, or a potential wiring failure.
Sep 29, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Lock light is flashing when I push bake it says door
Hello meathead4094 - Often when the LOCK light is flashing, it is because there is door malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear the flashing. If issue persists, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
Apr 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
WHEN YOU TURN OVEN ON AND PUSH BAKE BUTTON AT 400 AND PUSH THE BAKE BUTTON AGAIN THE PANEL WILL SHOW 400 AND BEEP AS IF READY BUT OVEN NEVER HEATS UP. SOMETIMES THE DISPLAY WILL RANDOMLY FLASH DATE. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MERH865RAB Electric Range
I have an Amana AFC 3355A Gas Range that will turn off and show an F1-1 signal when I try to bake. Today it would go to the same signal as soon as I tried using the broil unit. It would not even turn on....
Hi
Thanks for using FixYa. Error F1-1 in your Amana means that the temperature while cooking exceeded. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Amana ACF3355AS Gas Kitchen Range
Model #PER5510BAQ When I try to turn on "BAKE" the control panel shows "LOCK" is on. Would this possibly be the sensor/lock gone bad or maybe even the door latch switch?? The control panel seems to...
Some one may have pressed the child lock button(looks like a padlock pic) It locks out functions. Push and hold the child lock button for 3 or more seconds. If thats not it try running the clean cycle and then cancle it after a min. If door locks and un locks should be ok.
Nov 11, 2009 | Maytag PER5510 Performa Electric Kitchen...
Frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Feb 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven not heating KitchenAid KERC506HWH3
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Nov 16, 2007 | Kitchen Ranges
Maytag PER5510 Performa Electric Kitchen Range Logo
163 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
