Question about Yamaha HTR-5450 Receiver
Yamaha HTR-5450 Remote RAV206 won't work to turn volume down
Can remote be taken apart to clean inside?
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
marklights54
  • 12 Answers
SOURCE: I need the remote code for the Yamaha HTR-5740
0176,1176
http://www.comcast.com/remotes/universal.html
Posted on Mar 01, 2009
smarthome2
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
Looking for a programmable universal remote control to work on my Yamaha a/v receiver # HTR 5450
DON'T buy a universal, buy an original or a facsimile remote for that particular model. They are between 40 and 50 bucks.
yamaha receiver htr 5450 replacement remote Google Search
Jul 03, 2018 | Yamaha Audio Players & Recorders
My remote works fine except for the volume control to the receiver(HTR5440). How can I set this for response?
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-5440_black__u/
a good start would be a glance at the owners manual
this will help
perhaps you have a faulty remote
perhaps it got banged and needs the insides soldered like the IR diode at the top end
i see you mention it isnt working
so try another or take the remote to an electronics buddy who can click it open and check for a bad solder or etc...
Dec 09, 2014 | Yamaha Audio Players & Recorders
Yamaha htr-5840 won't work with comcast remote codes, tried all codes, nothing will work, remote is Comcast dvr 3 device
I have a Yamaha RX-V571 AV Receiver and the published codes don't work for my Comcast silver remote w/ Red OK button. Managed to make it work while living in MD. Now in FL, have new remote and don't remember how I made it work before. Would love some help. T Y
Sep 19, 2011 | Yamaha HTR-5840 Receiver
Where can i find a cheap RemoteControl for my "Yamaha RXV520 Receiver"? it could be also a replica or generic. thanks, Arik
Original $61, copy $39
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=rxv520&uuid=A12997127730091
The model forthe remote is RAV206.
If you lurk around eBay and search for "rav206 remote" or "RXV520 remote" and check the "include description' box, you may eventually find one for cheap.
Mar 09, 2011 | Yamaha RX-V520
Need instructions for Yamaha remote RAV206
This is the instruction manual for the whole receiver that uses that remote. There is no manual for just the remote, but this should be what you are looking for. I imagine you want to know how to use the remote with your receiver that it goes to, correct? The manual is at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5460.pdf
Thanks so much, let me know if that's not what you are looking (if that is the case) before rating my answer lower than 4 thumbs please :)
Thanks
Tim
Oct 15, 2010 | Yamaha Televison & Video
My RAV 250 remote for my HTR 5740 has button issues.
if you can open the remote try cleaning the board this will help make the contact
the other way to test remote is a camra on phone
turn on camra and press the buttons and if you see a flashing light then that button ok try the rest
Nov 28, 2009 | Televison & Video
I need a dishnetwok remote code for my HTR-5740 YAMAHA reciever
my phone say that initial programming needed can you sold this for me
Nov 01, 2009 | Yamaha HTR-5740 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
I'm getting no sound from my htr-5450 reciever
Check the "speaker selector" on the front panel. Make sure A, B, or both are lit up. Also, make sure the "6 ch input" is"off" it's a button right below the volume knob on the right If it's still not working, post a comment and I'll help you troubleshoot further. Hope this helps
Jun 30, 2009 | Yamaha HTR-5450 Receiver
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
Yamaha HTR-5450 Receiver Logo
248 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
