Question about IBM ThinkPad T60 Notebook
Ibm t60 will not boot after ibm updates
I have downloaded the ibm bios updates through the t60 Thinkvantage button. They downloaded, and looked like they installed. The machine said that it would need to restart and to make sure that the power and battery were not disconnected.
The machine shut down, but will now not start up again.
Can anyone help.
Cheers, AL.
The problem is sort of solved. I phoned the IBM Support centre; they said that the mother board was either broken or faulty. Fortunately the laptop is still under waranty and so an engineer will come and fix it. I must say the IBM suport centre was very efficient and quick.
There was no mention from them though that it was the bios update that may have caused the problem.
I'll update when the laptop is working.
Thanks.
Posted on Dec 22, 2008
My Lenovo Thinkpad T60 Won't load pass thinkpad Logo. I can't access Bios and ThinkVantage button is useless PLEASE HELP!
A burning smell is a good indication that some component burnt up. Could be a fan and that would cause it to shut down. If it's hung on the logo I would start by removing the memory, hard drive and optical drive and see if it boots past the logo. If it does then power down and add one item back in and test again until you find the bad part. Can you hear the fan spinning when you power it on?
Dec 02, 2012 | IBM Lenovo ThinkPad T60
Where can I download for free a missing manual for IBM ThinkPad T60
Hello visit the lenovo support site:
http://support.lenovo.com/en_US/downloads/default.page?selector=expand
Lenovo has the support for ibm products.
The ibm site is just for servers.
Select model number in search for drivers.
Or install this software:
System Update helps you reduce the time, effort, and expense required to support and maintain the latest drivers, BIOS, and other applications for Think or Lenovo systems. It enables you to get the latest updates from the Lenovo support site.
http://support.lenovo.com/en_US/research/hints-or-tips/detail.page?LegacyDocID=TVSU-UPDATE
Good luck
Jan 18, 2012 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Added a ST95005620AS in Lenovo (2503) docking station as a second drive and it is causing a slow boot in Lenovo T60
Very strange, I added a WD 500GB in place of my CD drive in my R60 and have had no issues. I suggest the following:
1. Pull the Seagate drive from the docking station, does the laptop boot faster (confirm the added drive is really the problem).
2. Put the drive caddy back in with a drive with one of another brand other than the Seagate, see if the performance imorives (confirm its the Seagate which is the problem and not the caddy or docking station).
If performance increases in both cases, do some research on compatibility issues between the IBM and Seagate drives. I would also go to Lenovo's website and update the laptop BIOS... this can easily be accomplished by downloading a tool and doing it through Windows. I had issues with using a non-Lenovo battery with my R60 till I updated the BIOS. Good luck, let me know if you get to the bottom of this. Please rate me if this helps you. Thanks.
Jan 04, 2012 | IBM Lenovo ThinkPad T60
I want to repeat my question again as follow: I turned on my Lenovo T60 it can not log in to Window because it show the check date and time message after that it show the Key's picture then I restart...
according to the levono support page at this link: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=YAST-3JWKJX
below is taken from the web site for a T60
Press the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
May 15, 2011 | IBM Computers & Internet
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
    How are you attempting to enter the setup (BIOS)? Here are the steps:
    Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
    Feb 18, 2010 | IBM ThinkPad T42 Notebook
    My ibm is lenovo t60 and i need bios password
    I would tell you to clear the CMOS. But, on those laptops, they soldered a chip on dedicated to saving password information, etc.. You'll have to replace the motherboard. If the pc's functioning fine, you can use the "ThinkVantage" button to restore the factory settings.
    Jan 10, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
    I Have An Ibm Thinkpad T60 2007-4AU. Restore Disks anyone?
    Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
    Jan 03, 2010 | IBM ThinkPad T60 Notebook
    T60 will not boot up
    There appears to be a BIOS update or two available for the Lenovo TP T60. One of the updates makes reference to this error code, but the verbage afterwards is a little different to that posted here. Mind you, my recommendation is that you should stay on target with BIOS updates because they are fixing problems with the computer, even if you don't realise you are having those problems!
    Please go here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64462.html
    Press Ctrl F and search for 2100. This tells you which update fixed a problem with ERROR 2100: At the bottom of this page you will find that these updates are for all regions. You will also find the link to the BIOS update utility.
    My experience of BIOS updates on the Thinkpad range is that you have to undock the laptop prior installing the BIOS update, and ensure the laptop has a constant power support - NOT BATTERY. Ensure you read the on-screen notes carefully.
    Hope this helps.
    Jan 14, 2008 | Lenovo Thinkpad T60 Notebook
    IBM ThinkPad T60 Notebook Logo
    337 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
