This did not happen for the first year of operation. Whenever the toilet is flushed the noise occurs while the tank is being filled. It is loud enough to be annoying. What do i need to adjust or replace? Thank you.
SOURCE: Leak at water supply entry into tank - Kohler Santa Rosa
Tighten the nut a quarter turn. If that doesn't do it then shut off the water supply. Unscrew the nut and get you a new rubber washer to replace the old one. If that doesn't do it, then go to the blue or orange box store and get you a new 12" stainless steel flex line for toilets. Bring your old supply line in to correctly match up the size so you don't have to make 2 trips if you buy the wrong one.
SOURCE: My Kohler toilet tank is
Change out the ball **** and float assembly and flapper valve to one of the newer types...
Also you can set the level of water in the tank by an adjustment screw located at the top of the ball ****.
The Flapper valve on the bottom of the tank also needs replacement, that is causing the tank not to drain properly.
This is a free answer, please rate me
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
SOURCE: valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
