Question about Microwave Ovens
Microwave rotating assembly jumps up and stops turning.
Our Kenmore 721.80803401 is approximately 3 years old and has had the same problem from day one. The rotating/sliding table jumps up and completely disengages from the rotating arm. As some others have noted, the problem will come and go, sometimes occurring frequently and then will disappear for several weeks. I have completely removed/inspected the table assembly from the microwave but have not been able to identify any sticking/damaged parts. The only questionable thing I found was that the rotating arm would sometimes pop out of its center hole, completely disengaging from the internal rotating mechanism. This would definitely cause the table assembly to stop turning and drop out mechanical time with the motor. I have been carefully inspecting the arm to make sure it is inserted completely but the problem has still been occurring.
When the table assembly pops up, the cooking liquid will often spill all over the glass plate resulting in a big clean-up. Other times we will be out of the room and not notice that the rotating table has stopped and the food will not cook properly.
If anyone has solved this problem, please post the solution as I am just about frustrated to the point of replacing this microwave/range hood.
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same microwave with the same problem. I called the tech support the first week after purchasing the unit because the tray was "jumping" and they sent me a new "rotating arm." That fixed the problem for about 3 years, then the same thing happened. I did not feel like spending $20 or so on new one... I took it apart and found that the "arm" (microwave ring) could/should be about 1/2 inch deeper/longer in order to fit over the motor. (it is holding on about 1/4" which slips and strips the microwave ring). The design sucks so the easiest thing is to keep buying new rings for it... I was hoping I would find a recall on this, but no such luck...
Posted on Nov 01, 2012
  • Microwave Ovens Master
  • 9,086 Answers
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Posted on Dec 21, 2008
I have a kenmore microwave toaster. Microwave no heat. table rotates OK and toaster works OK. What is most likely problem, HV diode, capacitor or magnetron?
Could be any of those 3 parts since they work together to make the microwave part work. Most common problem if under 5 years old would be the diode, then capacitor, then mag, but I have replaced mags on new microwave in some cases. Like I said they work together. Capacitors will sometimes swell up at the top or bottom but again not always.. This isn't much help but you need a multimeter and must know some test procedures on this one.
Apr 14, 2015 | Kenmore Microwave Ovens
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p][p]
Jul 07, 2010 | Kenmore 63663 Microwave Oven
Our Kenmore model 721.80833500 tray jumps off its track. This has progressively gotten worse over time and now the little end wheel on the rotating arm has broken off. The microwave still works and still...
Found 2 possible solutions on the net. (1) Check the engineering change at a Sears store. They reengineered the glass tray and the narrow plastic band the tray glides on. Get the new items from Sears. (2) Cut 1/4" out of the narrow plastic band the glass tray glides on. Possible solutions that look promising.
Dec 03, 2009 | Kenmore 80809 Microwave Oven
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
Dec 21, 2008 | Microwave Ovens
Carousel stopped turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
Model 72180883400 Microwave Oven F-9 Failure Code
If the unit is less then 5 years old i believe it is still covered it may be the inverter board or a grounded Magnetron tube. If you need any further assistance let me know. I would contact kenmore directly.
Thanks,
Lee
Sep 01, 2008 | Kenmore 62702 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
