Question about HP Computers & Internet
A horizontal line is visible in the middle of the monitor which cuts the data. I have purched the laptop yesterday. When I make the laptop stand by and use again the line is not visible. Please let me know whether this is a manufacturing defect or can be solved.
  • 191 Answers
Hi, sorry,what is "purched" mean? usually trouble comes LCD cable/cable plugs/sockets also at motherboard side, it could be dirty or temp disconnect, it is not easy to check and repair if you are not Engineer, due to easy to damage other component.
Only less defect by manufactory that is LCD panel board inside which you have to send warranty repair or change LCD panel.
you may try if you have experience of computer engineering:
1)open LCD panel cover check the cable to LCD rear socket, take out the plug and clean them using small brush then put it back.test it if trouble again do follow step:
2)open laptop up cover beside keyboard to find out where the LCD cable plug is and plug the cable out and in, test it if trouble again, do next
3) check all LCD cable from line to line between two plugs.
Important do all steps carefully.
Posted on Dec 21, 2008
Single horizontal line
you need to replace the horizontal integrated chip (IC), but can be done by only the expert technician. and the availability of IC for monochrome monitor is very rear.
Aug 21, 2012 | Goldstar MBM-2195A Ttl Monochrome Mga...
I have a horizontal line runnning right through the middle of my laptop screen
Sounds like a bad monitor. Do you have an external monitor you can plug into it to verify that it is not the graphic card?
May 12, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
I have a Sony vio model PCG-3E2L laptop computer, the problem I have is my laptop screen is getting a horizontal fine line at the bottom one inch above the line is of red color but color changes from...
  1. It smees your LCD is faulty.
  2. connect your laptop to a external monitor. Check if lines are visible or not.
  3. if no line are visible then need to change your LCD.
  4. for changing better to contact service centre.
  5. you can look for used LCD, which will be cheap.
Aug 21, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Horizontal lines in my laptop screen & its is increasing while using. it is also visible while using booting. it first happened shortly after washing with a liquid.
The display board in your monitor is posibly has liquid damage if it got wet. you will need to replace the monitor is this is the case.
Aug 11, 2010 | ASUS VW222U Monitor
Horizontal lines flickering
  1. Mybe VGA driver instalation not compatible with your monitor screen, you must check there are OR if you are use External VGA mybe theyare not compatible with your motherboard system
  2. if not work you must bring your monitor go to service hard,because your computer,because most likely your monitor easy damaged. good luck
Apr 25, 2010 | Microsoft Windows XP Home Edition
Monitor suddenly goes black with alternating horizonal lines, some thin some wide. Shut off for a while and now the picture is very washed out.
there are 2 parts involved in horizontal lines. videocard and LCD. if this is a desktop just diconnect the data cable from computer and check if the LCD self test will appear also check if you still see the lines, if lines are not visible in the self test definitely its your videocard taht you need to replace.
Oct 03, 2009 | Computers & Internet
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
Line across middle of screen and series of lines below that overlaying whats active on the monitor. It's a new 23 inch acer
Your screen is made up of layers in which gas is trapped. whenever any side of the screen gets cracked it may not be visible with naked eye. The gas gets released and you get a horizontal straight line blue or black. Initially it starts with a thin line and as the gas releases it keeps on getting broader. If your acer is on warranty try to replace it or else you will have to replace it out of your own pocket.
Sep 07, 2009 | Computers & Internet
Monitor ENVISION EN985e with Vertical failure
If you are looking to take the monitor in to get it fixed, you can try Best Buy. They have an in-house repair team called Geek Squad. For a store in your location just go to www.bestbuy.com
Mar 24, 2009 | MPC Computers Envision EN 985e (Dark...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
