Question about Whirlpool Refrigerators
Refridgerator door has started poping open
It has been fine till lately.
Now it just wants to keep poping open all the time.
  • Expert Brian May 11, 2010
    Have you tried removing all of the food from the front of every shelf and door bins? Even remove the door bins from the door? I would bet that the inside of the door or something in the door is hitting something on one of the shelfs... Hope that helps, Brian
    Novelist:
  • 161 Answers
Make sure the gasket on the door is clean. This gasket has a magnet inside that must make good contact with the metal area on the Ref.
Also, sometimes this gasket will lose its shape. A little heat from a hair dryer while working it back into shape with your hand will help.
Posted on Dec 21, 2008
How can I lock the wheels?
ever heard of a rubber door stop . small wedge shaped piece used to keep door open . FIND one or two and put in front of you refridgerator on the floor and push it under just a bit .
Mar 06, 2016 | Whirlpool Refrigerators
Rust appearing on 10 month old refridgerator doors
How can I put this nicely.
TAKE IT BACK!!!!!! First moisture is forming where it shouldn't, air leak/door gasket not sealing, and second stainless doesn't rust. If rust is forming than it's of poor quality. More iron in it than steel. Isn't there atleast a one year warranty? Don't wait! Till it's too late. Complain NOW!!!
Oct 30, 2012 | KitchenAid Refrigerators
Can't open the driver door from the outside, only the inside. Problem started very intermittently about a year ago...mostly when the weather was below freezing. Now it's an every day thing....what to do?
You will need to take the door apart, some times it's just a spring poped out of place, sometimes a little plastic piece broke, no telling till you get it apart!
Jan 24, 2011 | 2001 BMW Z3
I have a top freezer. Whenever the refrigerator door is closed, the freezer door pops open. There appears to be a good seal around each door... How do I keep the freezer door from poping open, when...
Replace the seals. It may appear to be in good shape but what is happening is the compressed air from closing the refer door is going up and releasing the seal on the freezer I would replace the freezer seal first as that should solve your problem.
Thx
Deathstalker
Aug 22, 2009 | GE PTS22LHR Top Freezer Refrigerator
My 2001 mecury mountianeer. fuse # 18 shorts out.. everytime i put a fuse it pops..it works the seats an door locks.
you have a loose wire grounding out and your fuse will keep poping till you find that grounding point !! check all the appropriate connections and harnesses. I hope this helps good luck
Aug 02, 2009 | 1997 Mercury Mountaineer
Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Mar 30, 2008 | Frigidaire FRS26ZSG
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
