Question about Car Audio & Video
Car audio Hi, would i be able to feed 2 JL Aaudio 12W7s with 1 Pioneer PRS-D2000SPL amp? thanks
  • kestas666 Dec 21, 2008
    and what alternator would do the proper job?
  • 15,935 Answers
(2) 3 ohm voicecoils wired in parallel net a 1.75 ohm impedence.
The amplifier will produce 2000W 1 ohm
1500W @ 2 ohm.
A 1.75 Ohm load will be somewhere inbetween.
Plan on 1750W.
Plenty of power for both in the proper enclosure.
Posted on Dec 21, 2008
  • blueextc3221
    blueextc3221 Dec 22, 2008
    Add up the fuses on the amplifiers to get your peak current draw.
    Add 30-35A for normal usage by the car.
    130A usually would do the trick.
    Ohio Generator makes stock replacements with pulley alterations and upgraded assemblies for reasonable prices.
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Bass freezes at a certain volumn and no longer gets higher
JUST CHECK THE CROSSOVER SWITCH, AND MAKE SURE THE SWITCHES ARE IN THE CORRECT POSITIONS
May 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Hi, will i be able to feed 2 JL Audio 12W7s with 1 Pioneer PRS-D2000SPL amp? thanks
Yes, that should have enough power. Remember to use 8 or 10 gauge wire to in stall amp, and 14 gauge for the speakers.
Dec 21, 2008 | Car Audio & Video
Jl amp
If the power supply feeding the amp is OK, it should have blown the fuse well before the voltage dropped to 5v. What size/type fuse do you have in the power wire feeding the amp?
Aug 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Pioneer prs-d5000spl
This sounds like an amplifier that trying to push a lower impedance load than its supposed to. Typical aftermarket car speakers have a 4ohm reading per voicecoil. By running more than one speaker per channel you can get more power(sometimes alot more) from the amp by feeding it a 2ohm load or more. If the amp isn't designed to handle ratings less than 4ohms a channel it will overheat and shutdown.
Mar 20, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
