If the evaporator coil is frozen over,then most likely the defrost terminator is bad its located on the top of the evaporator coil and is about 1" round,to test it it needs to be below 15 degrees as this is a bi-metal switch operated by temperature,it will show close to zero ohms when its cold if its good,otherwise the defrost heating element can be open its located under the evaporator coil,but its a calrod element and they usually dont go bad,you can check this with an ohmmeter also and will have anywhere from 20 to 75 ohms,if these are both ok,then the defrost timer or ADC automatic defrost timer can be bad depending on which system your unit incorporatesl
