Question about Smartlink (I56KSPF00) Modem
No longer dialing Lond Distance
Our current provider changed the configurations on the server and now we are not able to dial out for faxes long distance. I have tried all of the manual and nothing is working.
Mon modem SMARTLINK 56K ne fait pas la numérotation et je ne peut accéder à internet en bas débit
Posted on Dec 14, 2007
    Problem Solver:
  • 5 Answers
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Posted on Apr 09, 2007
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Mar 25, 2014 | Nortel Norstar M7310 Display Phone
I have two dell laptops that are having the same problem of no dial tone
First of all, be sure that the connection you have configured on the computers are Dial Up connections.
If you have restrictions activated on the telephone line, removing them might help. Some other services of your telephone provider can also prevent your modems to properly detect the dial tone. It might be worth to take a look in that direction.
It might also be a problem with the telephone line. Try also to dial the number normally entered in the dial-up connections. You should hear a ringing tone shortly followed by noises similar to a fax machine. If you hear this, you access correctly to your providers dial up server and the problem would be with the two computers.
Apr 28, 2011 | Dell Computers & Internet
Why is it when I am sending a long distance fax to another state I receive a code that says G3.
There are several reasons this could be happening.
  1. Does your office allow for long distance dialing and if it does, do you need to "Dial 9" or some code before dialing long distance?
  2. Have you dialed "1" before the area code?
  3. Is the area code correct?
These are the most common reasons why you would get a long distance error while faxing. Hope you find this useful.
Nov 16, 2009 | HP 1040 Plain Paper Inkjet Fax
Trying to fax and the machine says i need long distance
Then your phone provider probably doesn't currently have long distance service. Call them and ask. If you're not sending long distance might be how you're dialing. Might need a 1 before (areacode)-xxx-xxxx
Best of luck to you, hope you get it working
Oct 14, 2009 | Office Equipment & Supplies
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Can't fax
Can you send faxes to a local number? If you can the problem is likely to be that there is no long distance carrier set up for your new VOIP service. You could also try using a regular telephone connected to the same jack as the fax uses to try dialing a long distance number, this may give you a hint as to what's wrong. You should also contact Comcast tech support about this problem, the VOIP box may not be properly configured for long distance service.
Carl
Dec 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Smartlink (I56KSPF00) Modem Logo
208 people viewed this question
Top Smartlink Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
De ice
De ice
Are you a Smartlink Computer and Internet Expert? Answer questions, earn points and help others
