AKAI power supply
I saw that you work on these-what's the cost? Is it worth it or should I just get a new tv? Thanks
  • 2,336 Answers
Please write an email to jah2mil@hotmail.com for further info.
Posted on Dec 22, 2008
Lct2701td akai brand, plugged in, flashing red light, but will not turn on
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, purchase a Service Manual over the internet at Nodevice.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 20, 2009 | Akai LCT2701TD Television
AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
Jul 20, 2009 | Televison & Video
AKAI Flat Screen Monitor/TV
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searchingon the internet with the part number.
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
Dec 29, 2008 | Akai LCT3201TD 32 in. LCD Television
TV won't turn on
You will have a defective power supply if you remove back then remove the cage around the power supply you will see the defective capactors,maybe as many as 20 defective.replace all of them and tv should work like new.cost for all capactors should not run over 35.00
Nov 09, 2008 | Akai PDP4273M Television
RE: Akai LCT2715
You would have to remove the Power supply if you feel comfortable doing so or you could send the whole TV but that could cost a bit....
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT3201AD Tv will not stay on when you turn it on the light changes to green and then in about 10 seconds turns red again. TV is 1 1/2 years old. For awhile we were able to unplug it and plug it back...
I have just repaired one of these sets for the 2nd time. The problem is definitely the Capacitors on the Main Power Supply Board. If you are handy, you could replace them yourself, or You can send your board to me and I will make the repair for you. Akai initially used what I feel are sub-standard Capacitors on these boards, and I have found that by replacing most of them, this problem can be eliminated. My email address for repairs is Lakers4life42@yahoo.com
Mar 14, 2008 | Akai LCT3201AD 32 in. LCD Television
My tv Wont Turn On
My 32" hyundai LCD TV will not turn on. The power lead is ok the on / off switch on the side turns the red stand by light on and off. I am unable to get the LCD TV off stand by. I have tried the the stand by button and this does not do anything. Can anybody help.
Sep 08, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
