Hotpoint aquarius WMA58 spinning but not draining away all the water
  • Washing Mach... Master
  • 3,463 Answers
Suggest you check pump filter.
you will find it located at the rear right side of the m/c.
Remove lower rear panel, there you will see a large black hose, remove securing clip, and detach hose, the filter is located inside, remove and clean, make sure you put everything back in the same order you took it off.
This should solve your prob. Make sure the drain hose is not clogged and the outlet is clear also.
Plz rate my solution.
Thanks.
Posted on Dec 21, 2008
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius WMA58 washes, spins but won't drain water away !
I would check the filter assembly and the drain line to see if there is an obstruction visible or twist in the line that you could smooth out. The drain solenoid valve could be faulty and just isn't opening any longer. It's an electrically operated valve that makes a rather loud "click" when it energizes to open the drain and let the water flow out.
Dec 28, 2016 | Hotpoint Washing Machines
MY HOTPOINT AQURAIUS WMA58 IS NOT DRAINING WAT CAN THE PROBLEM BE
The solenoid in your drain valve has stuck closed or otherwise failed.
OR: the discharge hose has clogged or kinked.
Check;
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Mar 27, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
H, can a hotpoint aquarious wma58 be run on cold water supply only.
if you have two connections on rear then no hot and cold needed .. if one just cold water.. bsc appliances 07779933829 spares and repairs
Feb 27, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Not spinning or draining
Remove the lower rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve your problem.
Please leave feedback.
Thankyou.
Jan 04, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Banging washing machine on spins
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Nov 16, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WASHING MACHINE.
at back, take small bottom panel off. you will see a large diameter hose going from bottom of machine to the pump. undo this hose at the machine end and the filter is inside the hose. take out and clean.
be carefull, lots of water will come out if the machine has not drained.
best to disconnect from mains when you do this
Aug 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
