Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 cold start issue?
About 2 weeks ago, the power started turning off... intermittently. It appears the only time I am having this issue is when turning the TV on from a cold start. The screen normally goes black a few times before actually turning off. The TV is normally "ON" for a few minutes before this issue even starts. It never shuts down immediately after power up. After a min or so, I can power the TV back up using the front panel or the remote. Once cycling the power back on for maybe for the third time, the TV will stay on for the rest of the evening with no issues. This starts all over again when I power the TV up the next day. Any idea?
  • 3 more comments
  • Ferriswolf Jan 18, 2008
    I have the same issue with the same model RCA HDTV, model D52W20. Coldstart is touch and go, when this television does start up there are wavey horizontal line across the entire screen. If the room is chilly forget about it.
    From other places I have seen it suggested to check the power supply, and have contacts checked. Any other suggested would be appreciated.
  • grpiegodess Feb 02, 2008
    RCA D53W20B-
    the tv randomly goes off usually within 10 mins or so of being turned on. this started about a week ago. it will shut down and most of the time does not auto start even though the times i've experienced the problem it has attempted prob 3 times to come back on but in the end doesn't.
    any ideas? should we contact RCA/Thomson Inc?
    groupiegoddess1@gmail.com
  • bradsfotofuu Feb 06, 2008
    My Tv will simply not turn on anymore. THe light will come on and act like it is turning on then light shuts off. It then will turn on again for a few seconds and turn off. Then again turning on for a few seconds and shuts off. Tv never turns on. I've tried the unplugging. I know my fuses must be good otherwise the light would turn on to begin with.
    I understand that it could be a safety shutdown cuircit feauture.. If it is this how do I fix it? The tech repair people around my town reall don't handle RCA and don't have much good to say about them.
    Help. Please.
  • RdSim1 Apr 06, 2008
    My mother and I both have the same TV, and have similar on and off problem. Her's finally stopped turning on, and RCA repairman came out and said problem was with motherboard...a $560 part.Also it seems this is a common problem as the motherboards are on back order from RCA. Now I am waiting for mine to go out completely
  • ikyokogbaa Dec 20, 2008
    My RCA HDTV turns on and off by itself. Even when I try to turn it off, it does not. The other problem is notthing show up on the screen and a sheeeshs noise that drives me crazy.
I am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
I had my motherboard replaced about a year ago. now the television simply goes to black/blank screen but still continues to play sound. this TV is terrible and RCA has done nothing
to fix the problem, never gain will I purchase any product made
or manufactured by RCA.
Posted on Apr 07, 2008
    Problem Solver:
  • 12 Answers
I had this same issue with a 52" RCA.  It continued on like that for about 2 weeks, then got so it wouldn't display the picture properly. I took it for service and it turned out to be a few loose solder joints.  The tech checked and resoldered the entire "motherboard" for $150,
Hope this helps
Flyback
Posted on Oct 12, 2007
53udx10b hitachi rear projection big screen. replaced convergence chips 2 months ago. Worked awesome. Started having power issues 3 weeks ago. Turn on - kicks right back off. Used to be able to turn...
Sounds like the problem started out with an intermittent solder connection possibly on the deflection PWB unless the power relay has a bad connection or is breaking down under load. If it is not the power relay, I would check the connections under the deflection board - paying close attention to the area from T701 and T752 including the Horizontal output Transistor for a short. You also have a possibility of defective filter capacitors causing the problem as well.
Jan 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Intermittent power on 52" RCA TV
This is the ITC 222 chassis. Most likely the problem is caused by capacitors on the power supply module part# 265324 which is no longer available. The module has to be repaired to the component level. Look for capacitors that are bulged at the top. I usually get around $250 for that repair (Carry In Only). There are also other causes but someone would have to troubleshoot the problem.
Mar 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d56w20
your power supply is going or gone out now.DO NOT plug it back in again you could start a fire
Aug 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power/button blinks
these tv are easily repaired
if you dont know tv basic,
forget it
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
Have you tried a new power box they can surge sometimes and play up you should try a new one of them and see if they help
Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung hl-s4666w won't come on...
Circuit malfunction indicated. Have it serviced
Apr 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Intermittent Power Issue
your problem is intermitent resolder the power supply the horizontal along with the area of the flyback you could be having some lose solder also resolder.if that does not work check around in the power suply some bad cap,power regulator and even the flyback again.a check should be made on the microchip.if you cannot do it your self take the set to a tech.good luck
Mar 29, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA light comes on and then goes off. Tv doesn't turn on
Is this your set?http://tv.rca.com/NR/rdonlyres/A2ED8EB5-A0AF-401F-A380-3CB61D5EBEB1/0/D52W20_222Chassis.pdf If it is, there could be a bad solder connection in the start up power supply or there is a resistor that will get loose or change value. It gives the power supply the start up pulse from the flyback transformer. there are no user replaceable parts inside this set, and the longer you wait to get it serviced, the more its going to cost. Unless you have a service manual and understand how the SMPS works, please play it safe and call in a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Dec 09, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
454 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
