Question about Lexmark Computers & Internet
I CAN'T MY PRINTER TO PRINT. I BELIEVE I PUT IT ON PAUSE.
  • 111 Answers
Go to the control panel and check it under printers and faxes make sure it set as default you will have a dropdown menu with thw options, also make sure it is not using office document imaging
write back if you need more help
Posted on Dec 21, 2008
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
After each print the pause button will continue to blink and will not print another label. I have to manually open the print head, close it and press pause for it to print. I do not understand the...
The ribbon is the transfer rolls same thing.
But check if you have not activate the pause mode in your driver!
This is an option to have the printer pause after printing
Aug 04, 2011 | Zebra Z4M Printer
Spooler turned off
The print spooler servie might be turned off.
Click on start go to run type services.msc
locate print spooler double click it and then select startup type automatic and then click on start. close all the windows, restart the computer and then try again it should work.
Jun 22, 2010 | HP Photosmart C5280 InkJet Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
PRINTER IS IN PAUSE MODE. I REPLACED AN EMPTY COLOR CARTRIDGE HOPING THAT WOULD FIX THE PROBLEM, BUT IT HASN'T. I CAN RUN A test pattern and printer willprint it out . but if i try to print an email for...
Pause is set in your computer, you have to go to control panel, printers, and then right click on the printer icon for the printer you are using. Pause is about the third choice down and you need to un-check it and that takes it off of pause.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
Computers & Internet Logo
21 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
