Cannot get further than self test display screen, just moved comp to a different room
  • Leslie May 11, 2010
    what make of comp.? is it the monitor or the comp.?
  • 46 Answers
Have you checked with the monitor cable connections . if not please check it or else if u have graphic card try reseating it and also checked input mode of the monitor it can be check by pressing the menu button then settings
Posted on Nov 27, 2009
The spynet watch turns on the but the screen is blank I can hear sounds but can not see the menu screen
When exactly you lost the display?
Just right after turning on the computer?While working in Windows? Or every time you open a program or application?
If problem happened just right after turning on the computer, we have 2 point of failures: Monitor or the VGA CARD/MOBO Onboard.
To test your monitor. While computer and monitor is ON. Unplug the VGA cord at the back or the monitor and check if you will see a box moving across the screen says monitor self test.
If no display replace monitor.
It monitor self test passed. Connect computer to a different monitor and if problem persist then update the video card driver or the motherboard chipset. If all fails then you have to replace your video card or motherboard.
Pls do consider replacing the VGA cord as well.
Hope this helps.
May 27, 2011 | Computers & Internet
No reception. Says check reception.
I am assuming that you have a Midland WR-100 Weather Radio. The display is saying check reception because you haven't received any kind of warning, Required Weekly Test (RWT), or Required Monthly Test (RMT) in a while. Do not panic. All you have to do is just watch the radio either every Wednesday, the first Wednesday of every month, the last Wednesday of every month or whatever Wednesday the NWS radio station in your county does their test. They usually run them starting at 10:00 a.m.. Keep watching it throughout the day because it could start at anytime. The display screen will read whatever test you are getting. When you watch your radio, look for the advisory light to light up. If nothing is said on the radio, then that means they are running a test. Your light will stay on for a few hours, but it will eventually go off. If this doesn't help, try moving your radio to a different place in the room or another room. If that doesn't help, unplug the DC cable and take out the batteries, then re-install them again. Hope this solution helps.
Jan 17, 2011 | Audio Players & Recorders
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Getting printer stall code on screen...
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press and hold the "Plus" (+) button. While holding it down, press the "Scan" button. Once the screen changes, release both buttons. The screen will display the firmware version until the buttons are released. Then it will display 0: Button test.
2. Press the "Plus" (+) button once. The screen will display "Single Test Page."
3. Press the "Menu" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Monitor changing colors hpvs 15
Try the monitor with a different computer. If it work, then the problem is the other PC, if it does not work, then your monitor is failing.
good luck
Dec 13, 2008 | HP vs15 15"LCD Flat Panel Monitor
Self-test
well screen might be bad does it work on anther comp ? if so yes its bad if it does work on other cheak video card drivers and card itself ok thx nick
Mar 13, 2008 | IBM E74 17" CRT Monitor
Comp boots, no screen lighting
This sounds like the backlighting has faulted, as around the screen there are tubes lighting the screen up, if these are gone they are replaceble but i would suggest taking to a qualified repairer as it is quite a complicated proceedure and get a price first as it may be cheaper replacing the notebook.
May 05, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
