Question about Canon Pixma iP6600D InkJet Photo Printer
I have a canon ip660d photo printer. It gives me the error that there are two cartridges of the same color inserted. This is not true. All cartridges are in the correct color slot and color codes match the slot. Tried to reinsert the cartridge and it did not help. I have a canon ip660d photo printer. It gives me the error that there are two cartridges of the same color inserted. This is not true. All cartridges are in the correct color slot and color codes match the slot. Tried to reinsert the cartridge and it did not help.
  • 1 more comment
  • mauricetaylo Dec 29, 2008
    I have the same prob. My Canon Pixma iP6600D is a few years old, I only use Canon Original inks and up until now I rave about my printer. Have tried all tricks I know to no avail. Am getting frustrated because printer won't work at all.
  • Donald Holder Jan 07, 2009
    yellow tank error u071:two of the same color tanks installed?
  • tdevereux Jan 10, 2009
    same thing -
The Machine
  • 788 Answers
SOURCE: Printer wont recognize new or old cartridge
Use a Q-Tip and some clean water to clean the contacts behind the cartridge in the printer and on the cartridge itself. Then use a pencil with a clean eraser to polish the contacts. Be careful not to touch the part where the ink comes out of the cartridge.
Also, are you using Canon ink or third party?
Posted on Jan 11, 2008
cropp
  • 377 Answers
SOURCE: How to remove the ink cartridge from the wrong slot for canon mp530
halo dear
for mp530, you can use a plugins catridge ... as cahnge your chips original , after use that you can refill your catrigde as well
the price about $4-5
try this site for clear information
http://exchangerate.ws/inkjetprinter.php?printer=Canon+PIXMA+MP530&lazySID=LcuxpiHFCsshJVujrrruBaNoo1203340519
oke
thks
cropp
Posted on Mar 15, 2008
IB4G2008
  • 3587 Answers
SOURCE: Cannon IP1880 Cannot detect Cartridge
hmmm..well..you may find that new drivers help a bit.
get them here
Posted on Mar 20, 2008
comaire2004
press the resume button 5seconds(this disable ink cartridge monitor..
Posted on May 12, 2008
SOURCE: Not recognize ink cartrdige Canon 6700D
Best thing to do is just replace the the indicated ink cartridge. Reason being is that even though the cartridge still has ink in it, it is the metal contacts on the cartridge that have to communicate with the printers on-board memory. If the contacts on the cartridge are fouled and are not communicating with the printer, the cartridge is telling the printer that "I am empty and I need to be replaced", even if it is full of ink. This would apply to all six cartridges.
Posted on Mar 27, 2009
I just installed a new CL41 Color ink cartridge into my Canon Pixma mp210, and it does not recognize it. It keeps saying the printer is empty, or displaying Error Code E5. ANother thing is when I go to see...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark x7170 printer cartridge error
Remove the color ink cartridge and double check that the plastic tape, which you removed from the cartridge is completely removed. I've noticed that sometimes a small piece of the protective tape tears and stay stuck on the cartridge causing the printer to give a false error. When replacing the cartridge be sure its fully inserted into the color cartridge holder and the locking mechanism locks securely.
Jan 17, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I don't use the color I just bought a black cartridge but it won't print unless I change the color also. Is this true or am I doing something wrong. Or do I have to also but the color cartridge.
This is true. Printer manufactorers just want you to spend money on color cartridges also. And most printers are using the color cartridge to make the print darker,
Jan 09, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I inserted the magenta cartridge in the photo magenta spot and now all the colors are wrong I have a canon pixmapro 9000
this could be a manufactoring error(wrong ink in cartridge! make sure its the right color ink!
Dec 09, 2008 | Office Equipment & Supplies
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Photos
    give your printer a DIAGNOSTIC TEST , is a cleaning test procedure of the ink cartridges, there you should know if you need to replace the ink cartridges.hope this helps AJ
    May 08, 2008 | Canon PIXMA MP470 All-in-One Printer
    Color is way off
    Hi , need head cleaning , until the color will have true color .
    use original canon ink cartridge you will satisfy sharp colors.
    Jan 13, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
    Black and color cartridges
    have one black and one color cartridge in my printer but it keeps giving me an error message:
    Oct 14, 2007 | HP Officejet 7210 All-In-One InkJet...
    Canon Pixma iP6600D InkJet Photo Printer Logo
    67 people viewed this question
    old marine
    old marine
    mukhtar21 shaikh
    mukhtar21 shaikh
