Question about Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash/he4t (error code)
Du/f -- what does it mean? the door is locked. where is the kick plate. how do i open it to unlock the door manually? I need help. where do i find the codes and what they mean? HELP!!!!!!!!!!!
  • 12 more comments
  • Anonymous Feb 21, 2008
    I HAD the same problem, but figured out how to fix it. Push and hold the AIR DRY button down for 4 seconds, until the lock light goes off.
  • ziooo May 18, 2008
    code dl/f - and the wash doesn't start - This may it the door look tha not working? I could i fix that?? Please help Thanks Rainy
  • Anonymous Jul 31, 2008
    i keep getting a F on the screen what does it mean and it wont spin or drain help
  • Anonymous Aug 22, 2008
    the code dl f is on myt washer what do i do , and the door is locked ?
  • Anonymous Nov 19, 2008
    When starting a wash load, get the error code HF. Do you knowwhat that means?
  • fentyk Dec 29, 2008
    Did anyone find the solution to the error code HF?
    and where can I get a manual to Kenmore Elite He4t online?
  • luisa1970 Jan 05, 2009
    my washer have a error code f29 and the door is locked
  • riverrrat Jan 19, 2009
    getting f11 code on kenmore smatwash he4t
  • cmu1 Feb 21, 2009
    my washer is showing is beeping and showing the codes H / F. Does anyone know what the problem is?
  • BocaAli Apr 14, 2009
    I also have the Kenmore Elite Smartwash and have the HF error code flashing. It recently did this and backed up so much water in our wall that it leaked out into a bedroom. We thought that the problem was solved when we cleaned out the filter and checked the hoses. All seemed to work fine and we recarpeted the bedroom. Now (three weeks later) it is flashing the same error code again. Please help!
  • Anonymous Apr 23, 2009
    my washer's door is locked and the buttons wont do anything their supposed to do
    its completely frozen
    my washer's door is locked and if you press the buttons they will light up but wont do anything or even shut off when pressed again
    its completly frozen!!!!!
  • Anonymous Mar 17, 2014
    We have a Kenmore Ultra bake oven, it was working fine then I had the door open then a code : EO -F2- came o, What does that mean? We turned off all power then powered it up again and now it its saying it is locked, How do I unlock it?
My washing machine is giving me a HL code and I don't know why..help
Posted on Jan 10, 2008
    President:
  • 1,294 Answers
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Posted on Apr 11, 2007
  • prem mathew Apr 03, 2009
    The error FH will stem from the drain pump operation and sometimes from the flow meter itself. Unscrew the front bottom panel, 3 screws underneath. You can drain the water out by the drain pipe you see. The filter sits right in front and just unscrews. Make sure to have enough towels on hand or a wet vac to soak up the water from the filter. After you have checked the filter make sure both water valves are turned on, clear the error by pressing pause/cancel twice. Check to make sure the drain hose is not kinked and that there is no siphon problem, meaning your exit hose is not too deep into the drainpipe. If the error still returns after checking the above, the next thing to suspect is the flow meter itself. This sits right in line with the water inlet valves. It's just a reed valve that measures the amount of water entering the washer and monitors the pressure switch. You can access it by removing the top and it will be on the left side in line with the inlet valve. Look for holes in this tube, change if any.
    Try these sites for spares:
    RepairClinic.com
    espares.co.uk
    AppliancePartsPros.com
    mcminone.com
My washer has a SUD message and when I opened the door, sure enough it's full of sudes. What should I do?
Posted on Apr 04, 2009
Code dl/f - I must have older modle I can't seem to find the Air Dry Botton on the washer?
Posted on May 18, 2008
  • kiry1 Oct 06, 2010
    I also have the same code DL/F ...What can I do? I am not longer able to wash anything...
06 f
Posted on Jul 18, 2008
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Aug 23, 2009 | Kenmore Elite HE5t Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
    Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
    May 04, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE4t Washer Control lock lit, door locked
    121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
    Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore front loading washer
    brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Door stuck Locked Control Locked light on
    Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
    http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
    Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
    Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    5,063 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
