How do you remove tv stand for the toshiba 32cv505d so i can wall
Managed to remove the backplate but their is a section underneath which i cant see how to remove it
SOURCE: removing stand from tv
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Posted on Feb 09, 2008
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Posted on Mar 03, 2008
SOURCE: stand
How do I remove the stand?
Posted on May 31, 2008
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
Looking for table top stand for Sony LED TV
Just try by any authorized dealers for Sony. If not available, check www.alibaba.com
Nov 27, 2013 | Televison & Video
Remove stand on Toshiba TV
To disassemble it, you have to see some illustrations. If you wish to get more details about how to disassemble Toshiba TV, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disassemble procedure to many TVs are given in detail, with illustrations.
Jun 13, 2013 | Toshiba REGZA 47HL167 TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
2)Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3)Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4)Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
Jun 22, 2009 | Toshiba REGZA 47HL167 TV
Taking stand off toshiba regza tv
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Can not remove the rest of the TV stand
I am the owner of the Panasonic TX-32LZD60, and finally managed to solve the problem myself.
So for anyone else out there with a similiar problem, you need first remove the two screws at the back of the TV which are low down. Take of the small plastic casing. Underneath you will see two rows of a total of 8 screws, which go through a black metal plate. Remove these and the stand will slide out. Not bad for a girl!!
Dec 18, 2008 | Televison & Video
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Stand
Apr 13, 2008 | Toshiba Televison & Video
Toshiba 26HLV66
you will need to remove the jack pack cover on the back of the unit (plastic cover), it should pop off, then remove the screws holding the stand on (should be 5 if memory serves).. after that the stand should slide away from the tv.
make sure your wall bracket kit can support the weight and that the screws you embed in the wall are using hercules hooks, anchor bolts, or something similar... last thing you want is a dead tv and ripped up drywall.
hope this helps,
trin
Nov 16, 2007 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
