Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Hampton Bay remote control
My remote control light illuminates, but does not work in any mode. I took apart the remote control and found that the wire going from the IC Chip to the R2 resistor was broken. After using a magnifying glass, I soldered the wire to where it looked like it should go. The remote still does not work. Does anyone know where I can get a wiring schematic for M Series remote control?
  • skyhawk172 Aug 13, 2008
    Remote controller got wet and stopped working. Anywhere to get a replacement/
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
Posted on Aug 04, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
My ceiling fan does not work.It is a Hampton Bay. There is power.
Hampton Bay receivers are notorious for taking a dump, replace the remote. If you're just adding the remote... There will be 6 wires on the remote, a set of two (white and black) a set of three (white black red or blue) and a single small wire by itself. The single wire by itself is the Antenna wire, do not wire it to anything, or it will fry the board in the receiver.
Mar 31, 2010 | Hampton Bay 52 In.Carriage House II in...
My Hampton Bay 54shrl which has two wires only an a remote,the problem is the remote seems to work find and then it does'nt I disconnect the wires reconnect and then it works for a while I'm Baffled can...
We have four models range 54SHRL Hampton Bay three of which face problems in speed. We try to raise it in the remote and just stay at the slower speed. What can we do?
Jul 06, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Remote control, changed battery, still nothing
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
every electrical part store sells these spst ball chain switches,
as they are common to many makes of fanlight,
Jul 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
551 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
