Question about Epson STYLUS CX5900 Printer
Changing printer cartridges
I have lost the maintenance manual and need to change the cartridges - how do I do it ? I have the 4 replacement colour cartridges but don't want to damage machine when I change.
Also why is the line in middle and reducing size of my laser copied photos when I copy them ? Is that due to cartridges not being changed ? I had no problems before but now I see this carriage is stuck in the middle and recuces size of anything I copy.
Please advise.
Thank you.
    Sergeant:
  • 191 Answers
Please you try a changing a had new and check the your prblem.
and printer use is manual defold.
Posted on Oct 21, 2009
Color ink is coming out blue
That means the colour cartridge has failed, as only one of the three colours are working. Try running a head cleaning routine, that may clear it, but don't do too many as it will use up all of your ink.
You may need to replace the colour cartridge. The following YouTube video shows you how to change the cartridge.
Canon MX410 Changing the cartridges
Feb 25, 2015 | Canon Pixma MX410 All-In-One Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
I've followed the step-by-step procedure for changing the ink cartridges and the printer tells me that replacement is completed but the colours replaced are not printing.
Hi
your printhead is clogged
try cleaning printhead from printers maintenence menu
In case I had help you pls vote me
it is the only way we get pay in this site
Nov 06, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
How to replace an ink cartridge on Epson Dx7400.Cyan has run out TO712.I have lost my user manual and I cannot remember which button to press to get the Printer part to the right spot for changing the...
On your printer and then click on the start menu goto Printer and Faxes. After that goto your default printer Epson Stylus and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center thats the time you can change the cartridge. Then close the cover when your finished to change the cartridge. Then click the next button and so on to finished.
May 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
C6280 printer color why does it say replace cartridge even after i put a new one in
Hi, This printer takes the "02" cartridges. If the cartridge is not being detected is because the "chip" in the cartridge is defective. Also because this printer takes 6 cartridge, make sure when you are changing the cartridge you are meant to change. For example lets say that blue and light blue are both low. Then light blue actually runs out and needs replacing. Make sure you do replace teh light blue instead of teh blue.
A way to validate this would be in the default screen of your printer the display show the amount of ink remaining on each colour. If you are replacing the one with no "bars" and with the warning symbol and after insertion the printer doesn't recognize the supply (ie shows the message of "HP original supply installed" and go through a "maintenance routine", the your supply is defective :(
Oct 04, 2009 | HP Office Equipment & Supplies
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson STYLUS CX5900 Printer Logo
153 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
