Sony WEGA Tube TV Model No. KV-32XBR400: At power up hear the click of the relay, screen lights up but there is just a single coler with fine horizonatl lines (soudn is OK). after about 5 - 10 seconds it shuts itself off. Unplugged for a while and problem remains. TV worked great up until now... Tom McL
  • Televison & ... Master
  • 509 Answers
A service manual for your model/chassis series is available (free PDF - 100% clean).
Elektrotanya for electronics experts
It sounds like a blank raster with retrace lines (no picture) which would be some kind of video fault. You could check C-board (Video OUT (IC9001-IC9003)) and progress from there. Also, being a CRT set, there may be a few bad solder joints everywhere - especially around the flyback transformer, and, with set unplugged, look for ruptured or bulging electrolytic capacitors in the video, vertical and HV areas of the chassis. Also check the horizontal output transistor(s) and associated tuning capacitor(s) to make sure they are OK (if they are, you can rule them out as suspects). It's a start.
Posted on Dec 22, 2017
  • 124 Answers
SOURCE: sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
SOURCE: Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
Posted on Oct 16, 2008
  • 4 Answers
SOURCE: sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Posted on Jan 01, 2009
    ArnelM
    • 184 Answers
    SOURCE: my sony grand wegar tv
    If you haven't done so, replace lamp part#XL2000U
    Posted on May 27, 2009
    welcomejee
    • 10594 Answers
    SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
    5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
    2 possible reasons, either Lamp is gone or Ballast Supply got bad.
    Replace lamp first, in most cases it solved the problem.
    How old is this TV and did you replaced lamp recently?
    Thanks.
    Posted on Oct 21, 2009
    I have a sony trinitron kv-32xbr400 it works but the picture is almost like its out of focus it has lines running thru it
    The description that you give indicates a video problem, it is a situation where the picture tube is over driven and makes the picture bloom and produces white lines on a angle, this is caused by an open resistor or a shorted video driver usually located on the back of the picture tube, "video board"
    Dec 30, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony 32" xbr trinitron trusurround T V picture is black
    Most likely on a trinitron tube if it is dark is the high voltage capacitor has blown. This is the device that feed the 30,000 or so volts to charge the tube, it attaches at the back with a clip and ****** and a single cable coming from it.
    You can check easily if it is definately that as you will notice if you power the tv on and off once or twice if you get that static charge feel from the screen, if there is none there then almost certainly that is the problem.
    Mar 10, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    KV-32xbr400 switch problem
    Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. in yor case you have 5 blinks that´s why the last is short to be possible the count..Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
    May 18, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony wega trinitron won't turn on
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Tv turning off
    Hello
    Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
    Regards,
    Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony wega kv-32xbr400
    My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
    Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    KV-32xbr400
    There are no hazards, Just a Picture tube trying to tell you something. The tube is defective. There is no way to fix it, but to replace the tube. To replace the tube is not cost friendly. Cost of tube $707.00 part number 8-735-047-05
    Best regards
    circuitcity
    Dec 01, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony kv-32xbr400
    Mar 26, 2006 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Televison & Video Logo
    65 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
