Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
No audio can not hear any audio from tv but hear oriental music can freq be off
    Problem Solver:
  • 7 Answers
It does use RF to communicate...theres that possiblilty, not much but somewhere to start.. merry christmas
Posted on Dec 25, 2008
Wondering if there might be an EASY WAY to hook my android 6,0, up to my tv? So i can hear my phones music through my t v speakers? Thanks!!!
If your TV has a computer input you can use the audio input jack next to the video connector for the computer on the TV with a cable that has the correct size plugs. You won't get a picture but you will hear the music from your phone. If your TV has no audio INPUT jack, then there is no way to connect your phone to the TV.
Oct 03, 2017 | Android Cell Phones
BOSE 2 AND VCSX OVER DISTORTION
have a tech look at your set you have some bad caps in the audio circuit along with your audio out put transistor or ic.have it replace along with the bad caps.good luck my friend.
Jun 10, 2007 | Bose VCS-10 Center Speaker
HOW DO I SWITCH MY SOUND SO THAT I CAN HEAR MY TV MUSIC OVER JVC KINO CENTRE
On your TV menu option there should be an option for audio. Open the audio option and choose the type of sound you prefer.
Sep 14, 2014 | Televison & Video
How to replace a fuse on a bose sounddock
Assuming you have a Sounddock Series 1 the Low end Bump -Bump, nine times out of 10, the Bump is the power supply connector inserted in the wrong orientation. Check you have the plug correct. If it is correct then look on www.invebo.com for the diagnostics video.
Feb 28, 2012 | Bose SoundDock Digital Music System for...
What FM frequency does the radio need to be on to use a wireless Disney Mickey mouse microphone?
Each microphone has a different FM Freq. If you can not find a Freq there is a very small hole in the mic near the Mic switch. You will need a jewlers screwdriver to make a freq. adjustment. Hold down the applause button while very close to your FM radio. Use manual tuning on your FM radio until you hear applause. If there is a local station playing on the Freq you can insert the jewelers screwdriver into the small hole and change the FM Freq for the Mic. You only need to make "fractional adjustments" to change the Freq. setting. Once you make a mic freq. adjustment change the radio freq SLIGHTLY up and down until you hear the applause.
This should get anyone going that is having difficulty with this microphone.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Toys
In my television sound is not coming
You will need to have some knowlege of the electronics within. First of all check the speaker, speaker line, try to see if you can coonect the audio- out to an amplifier to get the sound. If so the fault could be the amp in the TV , If not the fault could be in the IF circuit. Also check to see in the sound settings menu if the freq. set is accordingly, change to the sound freq required for the colour choice or put in auto mode..
Jun 29, 2010 | Samsung DLP HL-P5663W 56" TV
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
Only one channel has no audio
check your tuner settings
you might be using UHF instead of VHF
Dec 12, 2007 | Curtis CM19102 19" TV
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
90 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
