Question about Sony XR-M510 Cassette Player
Cd change will not work
When i press sauce from listerining to the radio the head unit turns itsself off and desplays reset in the desplay i pressed the head unit reset button it didnt do anything except reset my radio stations i had just programmed in
can anyone help me solve this mistery?
  • hall205 Dec 22, 2008
    no nothing to do with the amp mate.
    check the bolts holding the feet on the the changer i just had this same problem you are using the wrong bolts to bolt the feet to the changer use shorter ones!!!
    this will solve your problem
    and to answer you other question no there is no reset button on the changer at all!
    hope this solves youre problems
  • 15,935 Answers
Power Antenna Wire hooked up as amp turn on. Switch the blue wires around.
Posted on Dec 22, 2008
I am pressing mode button of lg ac but cooling sign is not desplayed.auto and dehumidifying is dysplayig.now how i can solve this problem.pls help.
Disconnect power to the wall control panel and to the AC unit and wait 5 minutes, then reconnect and see if it resets itself.
Aug 03, 2016 | LG Heating & Cooling
Desplay quit working on my express rci and I would like it fixed
You can email "Droo" at sales@tss-radio. He should be able to fix back light issues. He works for TSS Radio, an online retailer for these parts and accessories.
May 20, 2012 | Delphi XpressRC XM Satellite Radio...
Desplay showing 0.000000 00 help! I don't know
The calculator is set to scientific notation. To change out of it, press and release the f key then the decimal point key and then a digit key representing the number of digits you want to the right of the decimal point.
Feb 15, 2011 | HP 12c Calculator
How to set clock on cd2000b and can clock become main display when radio is in use?
Ya the clock can be the main display Press the buton at the bottom (one of the three button found on the left hand side) with the button found on the right hand side of the cd player (first colunm at the bottom... If u not sure wat i mean try all of the 6 buttons on the right hand side). Once u have the clock as desplay press and hold same buttons but this time longer untill The clock start to blink. Then use the radio tuner to ajust hours and minutes. Finally press only one of the button u used before (the left one)...all done!! Good luck
Dec 25, 2010 | Clarion (DB165) CD Player
After changing oil in a 2007 hhr, how do you reset the oil life
Turn Ignition to RUN
Press "Information" and "Reset" buttons at the same time on the DIC to enter personalization menu.
Press " Information" button to scroll through avalable options.
until DIC desplay shows OIL-LIFE RESET
Press and hold "RESET" button ubtill DIC display shows " ACKNOWLEDGED"
This will tell you that the oil life has been reset.
turn key to " LOCK"
Sep 13, 2010 | 2006 Chevrolet HHR
Desplay not working, can I change the desplay and cost
Yeah you can replace it. I would suggest you to go to a mobile repairing shop and get repaired or you can to the service center. They'll charge you for the new display and for their service.
Good luck.
Thanks for using FixYa.
Jun 17, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Changed drum but it is still saying 'change drum'!
On some printers after you change the drum, you have to reset the counter so the printer knows the drum has been changed. How to reset the counter is as follows:
1. press the ONLINE button to return the printer to off line status.
2. press the MENU button repeatedly until the MAINTENANCE MENU is desplayed, then press the SELECT button.
3. Press the item button until DRUM COUNT RESET is displayed.
4. Press the SELECT button and the Drum Counter is reset.
Hope this helps.
Nov 10, 2008 | OKI B4350 Laser Printer
Sony XR-M510 Cassette Player Logo
94 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
