Question about Neff 18 in. S5943 Slim-Line Built-in Dishwasher
Dishwasher will not staart.
I have a fully integral Neff dishwasher which: a)won't start and;
b) when i do fiddle around and get it statrted won't fill with water.
It has an electronic water valve which i have taken apart and put back together but still without success. Could there be a door switch problem? or do you think this is a water feed issue or both? How do I test the suspect components?
Many thanks
KS
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
SOURCE: Neff dishwasher continuously attempting to pump out water
Had the same probelm. Left the machine idle for a few days. By the time I found this solution, the water must have evapourated. The machine worked when I tried it. Underfloor heating probably helped evapouration. The original pump obstruction was caused by a piece or broken glass, so caution recommended when cleaning out the pump.
Posted on Sep 09, 2008
  • 1214 Answers
SOURCE: dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Posted on Jan 28, 2009
SOURCE: Neff dishwasher removal
Hi when you open the door there are two hole about a therd of the way down each side you will be able to see the screw head undo these then pull door up. it will come off quite quickly so becareful.
Tony
Posted on Mar 28, 2009
  • 10865 Answers
SOURCE: Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
Posted on May 21, 2009
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff 18 in. S5943 Slim-Line Built-in Dishwasher Logo
46 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
