Question about Lexmark Optra T614 Laser Printer
I need help.
My printer all way say paper jam. and won't come out of the printer.
    Scholar:
  • 31 Answers
If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
Posted on Aug 17, 2007
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
There's no foreign objects in my printer and I also put the paper in properly... I have ink, etc... My paper gets jammed immediately on the right side when trying to print. Help!
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 23, 2011 | Office Equipment & Supplies
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
The paper jams when I try to print. It will not feed from either the lower or the upper paper feed. It is jamming in the back of the printer.
Paper jams
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Open the Rear Cover.
If you can see the jammed paper, slowly pull the paper out.
Clean the rollers in the rear section too.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Canon PIXMA MX850 Multifunction Printer
Lexmark Optra T614 Laser Printer Logo
204 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
