Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker not making ice
How far into the line will the water freeze (the hose that feeds the icemaker)
    Scholar:
  • 111 Answers
The water in the line up to the icemaker doesn't freeze until inside the icemaker mold cavity. Think of it like you are pushing a child up the ladder to go down a slide. The ladder is warm. Once over the top (where the cold starts) the child slides to the bottom so doesn't stay in the cold very long. Strange analogy but if you think about it should make make sense (hopefully). Brian
Posted on Dec 21, 2008
  • 4 Answers
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Icemaker not making ice
If no water is getting to ice maker either the water feed solenoid is not working, the water line is no good, or the cam mechanism of the ice maker is not switching the solenoid on.
Oct 05, 2016 | Refrigerators
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Ice make has stopped making ice
Try filling the icemaker with a cup of water where the ice is made. Make sure the shut off arm is up. wait like a day. if it does make ice then you water valve needs to be replaced. if it doesnt replace the ice maker. also dont forget to check the tube behind the ice maker. it feed the icemaker with water. if that freezes up then water cant make it to the ice, thus ice maker and valve are fine. get behind the frig at the upper top right behind where the ice maker is but outside back. there is a tube that can be pulled out that is the feeder tube make sure no ice, do this ok?
Mar 27, 2010 | Refrigerators
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Nov 04, 2008 | Frigidaire FRS26ZSG
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
551 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
