Upgrade processor and graphics card for Gateway 4026
Recommendations?
  • 1 more comment
  • EndTimer Dec 21, 2008
    Follow this link to get Gateway info on the product:
    http://support.gateway.com/s/Mobile/Gate...
    Thank You
    Here are the specs on the Gateway 4026
    What new upgrade for processors and graphics cards are possible. Thank You.
    4026GZ Notebook Specifications
    System Gateway® 4026GZ Notebook
    Processor and core logic
    Processor Intel® Celeron? M 350 1.30 GHz
    Determine Your Processor Speed
    Chipset-Northbridge Intel® 852GM
    Chipset-Southbridge ICH4-M
    Architecture 130 nm
    Level 2 cache 1 MB
    Front side bus speed 400 MHz
    BIOS Phoenix BIOS
    4 MB Flash ROM
    SMBIOS 2.3 support
    Advanced Configuration and Power Interface 1.0b and 2.0 (ACPI 1.0b and 2.0) support
    Wired for Management 2.0 (WfM 2.0)
    System memory
    Memory type 333 MHz DDR RAM
    Installed memory 256 MB
    Memory expansion options Two 200-pin industry standard DDR-SODIMM sockets
    Accepts two 333 MHz DDR RAM memory modules in memory bay
    No internal memory
    2 GB maximum system memory
    Determine Your Notebook's Memory
    Adding or Replacing Memory
    Video
    Graphics controller Intel® with 32 MB UMA Video Memory (chipset integrated)
    2D hardware acceleration
    3D rendering acceleration
    Video memory 32 MB UMA (shared memory) architecture with Dynamic Video Memory Technology (DVMT)
    LCD display panel 15.0-inch active matrix (TFT) LCD color display
    Maximum Resolution: 1024 × 768
    Maximum Color Depth: 32-bit (16.7 million colors)
    LCD maximum refresh rate 60 Hz
    Controls Brightness level selectable through FN keys (up, down)
    Auto dim on battery and auto bright on AC power (selectable in BIOS)
    External video Supports dual display and extended desktop
    External CRT resolutions Supports standard IBM VGA compatible modes
    Maximum resolution: 1920 × 1200
    Maximum color depth: 32-bit (16.7 million colors)
    External CRT maximum refresh rate 75 Hz
    Audio
    Sound support PC2001 compliant AC' 97 audio
    Note: This notebook does not have an internal microphone.
    Volume controls Volume control toggle
    Press wheel in to mute the sound
    Software control provided through Windows®
    Internal speakers Stereo speakers built into front of notebook
    1.0 W maximum output for each channel
    Audio jacks Stereo headphone output
    Monophonic microphone input
    Communications
    Modem features Integrated V.92 56K modem
    Uses the RJ-11 jack on the rear of the notebook
    Supports Wake on Ring from S3 power mode
    10/100 Mbps Ethernet interface features Integrated IEEE 802.3 (10/100 BASE-TX) Ethernet interface
    Uses the RJ-45 jack on the rear of the notebook
    Supports Wake on LAN from S3 power mode
    Wireless Ethernet interface features (Factory installed option) FN+F2 keyboard combination turns wireless Ethernet on and off.
    Antenna: Uses factory-installed diversified internal antenna
    Operating channels: 11 selectable channels
    Security: 128 and 64 bit WEP encryption
    Operating Frequency: 2.4 GHz Direct Sequence Spread Spectrum (IEEE 802.11b and IEEE 802.11g)
    Maximum Data Rate
    54 Mbps (IEEE802.11g)
    11 Mbps (IEEE802.11b)
    Input/Output (I/O)
    Keyboard U.S. English keyboard
    Full-sized 84-keys
    19 mm × 19 mm key pitch
    2.5 mm keystroke
    Pointing device Gateway EZ-Pad? touchpad with vertical scroll
    2-button design
    Status indicators FN+F1 keyboard combination turns status indicators on and off.
    AC power
    Wireless Ethernet
    Caps lock
    PAD (Num) lock
    Scroll lock
    Hard drive access
    Battery status
    Power/Suspend
    Input/Output (I/O) ports Four USB version 2.0 (4-pin)
    IEEE 1394 (4-pin)
    V.92, 56K Modem (RJ-11)
    10/100 Ethernet (RJ-45)
    External monitor (VGA)
    PC Card socket (one Type II)
    DC input
    PCMCIA Accepts one Type II device
    Ricoh R5C590 controller
    Note: This notebook does not support Zoom Video.
    Storage
    Hard drive 40 GB
    2.5-inch diameter
    9.5 mm height
    Replacing the Hard Drive
    Memory card reader (Factory installed option) Supports the following card types:
    Memory Stick®
    MultiMediaCard?
    Secure Digital?
    Optical drive (Factory installed) Combination DVD/CD-RW
    Power
    AC adapter 19 VDC, 3.42A, 65 W output
    Automatically adjusts for 100 to 240 VAC, 50 to 60 Hz power sources
    Two-wire design
    Battery type Removable Lithium Ion battery pack
    Embedded controller inside to support smart battery
    Battery capacity 6-cell Li-Ion
    4.4 Ah
    11.1 V nominal
    48 Wh
    Note: Battery life varies depending on configuration, programs, power management settings, and features used. Recharge time varies, depending on usage.
    Power management Advanced Configuration and Power Interface 1.0b or later (ACPI 1.0b or later) support
    SMBIOS 2.3
    PC 2001 compliant
    CPU may support Intel® Speedstep? technology
    Controls Icon on taskbar shows battery charge as a percentage remaining
    Power switch Supports Power On/Off, Standby/Resume, Hibernate, Shutdown
    Lid switch LCD On/Off, Standby, Hibernate
    Security
    Passwords Power-on password (user/supervisor password set in BIOS)
    Hard drive password
    Physical Main system memory compartment screw
    Hard drive kit screw
    Mini PCI bay screw
    Kensington® security slot on notebook back
    System software
    Operating system Microsoft® Windows® XP
    System management SMBIOS 2.3 BIOS support
    Support for Wake on LAN from S3 power mode
    Support for Intel® LANDesk® Client manager 6.0
    Wired for Management 2.0 (WfM 2.0) enabled
    System compatibility PC2001 specification
    SMBIOS 2.3
    Windows Hardware Quality Labs (WHQL) certified
    Quick boot Supported
    Physical specifications
    Dimensions 12.9 × 10.5 × 1.0-inches (W × D × H)
    328 × 268 × 27.1-millimeters (W × D × H)
    System weight 5.5 pounds (2.5 kilograms)
    Includes optical drive and 6-cell battery
    AC adapter weight 11.5 ounces (357 grams)
    Includes cord
    Battery weight 10.4 ounces (322.5 grams)
    Environmental
    Operating temperature 50°F to 90°F (10°C to 32°C)
    Storage temperature 4°F to 140°F (-15°C to 60°C)
    Operating humidity 20% to 80% relative humidity; no condensation
    Any specific type of Intel Pentium 4 Mobile, 1.6 GHz? I needed a AMD X2 specific to 939 motherboard when I upgraded the processor on one of my older computers. What about this Laptop?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Recommendation(s): replace the unit. Sorry but that would be the most practical/realistic with less challenge.
Rationale:
  • currently running a Celeron 1.3GHz processor, not that many readily available replacement Pentium IV processor still in the market that would match the pins and socket;
  • video engine is most likely built-into the motherboard and uses only 32Mb and therefore would not be upgradeable;
  • the 333MHz memory speed is likewise a factor to be considered.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
    President:
  • 2,110 Answers
May I know which model no . do u have..
  • Sibananda Jena
    Sibananda Jena Dec 21, 2008
    it can support upto
How can I upgrade Gateway E-475M graphics from integrated intel
Can't do it mate. You have a laptop. The reason why it's called an integrated chip it because the MB main processor is ALSO handling graphics. If you had a desktop, you could insert a graphics card in an available slot and disable the Intel integrated graphics after installing a new graphics card. Can't do it with a laptop! Sorry mate...
Jul 13, 2014 | Gateway 31na1mb00e0 Motherboard E-475m...
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Can I upgrade my graphics card for my Gateway NV59C41U laptop?
Yes here is a link to a nifty way to have an external PCI Express slot on your laptop where you can add any PCI Express Video Card! :)
If you have 4GB of ram then you need to have a 64 bit processor or you will have a 4GB cap with the video card ram and the ram installed I believe.
http://www.techradar.com/news/computing-components/graphics-cards/how-to-make-an-external-laptop-graphics-adaptor-915616
Good luck and have fun :)
Christopher
May 17, 2012 | Gateway NV59C41u LX.WJU02.025 Notebook PC...
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
Sep 20, 2010 | Gateway Essential 400 PC Desktop
I have a mobo C51PVGM-GB that I would like to upgrade the video card and not use the one built into the Mobo.
You are upgrading the graphics.
Instead of using Integrated Graphics, you will be using a dedicated graphics card.
Integrated Graphics is also referred to as OnBoard Graphics.
On the motherBoard.
The GPU (Graphics Processing Unit) is soldered to the motherboard.
It is not a video (Graphics) card.
A dedicated graphics adapter card has it's own GPU, and graphics ram memory.
http://en.wikipedia.org/wiki/GPU
Information on the Gateway 4006136R - Nvidia GeForce 6150 AM2 uBTX 1394 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
Viewing this small photo of the motherboard, the Orange long slot you see is a PCI Express x16 slot.
1) The Northbridge chip is a C51PVG
2) The Southbridge chip is an MCP51
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply Processor for short)
3) Made by ECS
4) Has an AM2 processor socket on the motherboard, for AMD processors.
Continued in an additional Comment.
Jun 12, 2010 | Gateway GT5220 PC Desktop
Gateway GT5222E windows Xp upgraded to Windows 7. Need upgraded video card, integrated video not compatable. Can I upgrade with video card?If so what can I get to do this.
Just go to best buy and find a video card that meets DirectX 9 Graphic specs that will fit you mother board.
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    Nov 11, 2009 | Gateway Computers & Internet
    Upgrade video card on a gateway 5200 xl pc
    You can get this card right now on e-bay for $53 including shipping. Not htr fastest but much,much better,I believe.
    New EVGA GeForce 8600 GT 256MB GDDR3 Video Card PCIE 16
    Dec 23, 2008 | Gateway 5200XL PC Desktop
    Upgrade processor for Gateway 4026
    Looks like a 2.0 Ghz Pentium M will fit. This baby will smoke your Celeron.Looking at prices you can get a new laptop for half again as much. It will set you back 300 bucks on New egg.
    Dec 21, 2008 | Computers & Internet
    CPU Upgrade
    you should upgrade computers, because a pentium 2 and 3 wont do ****.
    Jun 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Computers & Internet Logo
    Alun Cox
    David Payne
    David Payne
