Back to:
Tags:
Nikon S3 Rangefinder Classic 35mm Camera
How do I avoid red-eye in my pictures?
By Gary10 - usenet poster
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Pasty
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The best way to avoid red-eye is to have the flash as far away from the lens as possible. If you can mount an external flash onto the flash bracket, use that instead of a built-in or pop-up flash. Similarly, you can use bounce mode to make the light fall on the subject at a different angle/direction from the lens.
If you can get away with raising the ISO, widening the aperture, and/or lowering the shutter speed so you can do without a flash, you can avoid red-eye altogether.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do I avoid red-eye in my pictures?:
I don't want to Accept this solution
Solution #2
posted on Apr 11, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
  • eyE`-deR`#
Thank You!
Solution #3
posted on Jan 24, 2007
Not Rated (0)
gnord
Rank:Master Master
Rating: 90%, 14 votes
Red eye only happens when the flash and the lens are quite close, and the room is rather dim, and the subject is looking at the the camera. (or quite close to it.)
That's because what you are seeing is the picture of your flashgun projected on th eback of the subjects eye, reflected back out along the line of sight to the rough vicinity of the flashgun.
If you elminate one of these factors you will reduce red-eye.
One option is to employ a pre-flash, that is an extra flash before the main flash.
This is built-in to some cameras as an anti-red-eye measure, others simply use a very intense light on the front of the camera.
The idea is to deliberately dazzle your victim (Sorry, subject. ) and cause their pupils to contract just before the main flash. That reduces the amout of light getting into their eye and illuminating the retina brightly enough to be seen.
If this is not provided by the camera you have, you culd try to dazzle the subject yourself, with a separate flash or similar!
However, you could try getting the subject to look just to one side of the camera at the right moment. (Hence 'watch the birdie') This will still look like the subject is looking at the camera, but will reduce the red-eye effect at least a bit.
The favourite method is moving the flash away fro the camera. That not only reduces red-eye but adds 'modelling' to the image. (Shadows, that is. Not young ladies in unlikely garments.)
Thank You!
Can you Help with these Film Cameras problems?
Film Cameras
A friend game me an Olympus XA1 Camera with an Electronic...
Film Cameras
I recently picked up a Ricoh KR10 Super. The problem is...
Film Cameras
Hi, as you advised we removed the bottom of the camera and...
Film Cameras
i recently purchased 2 minolta 35mm's. an xg-1 & xg-9....
Film Cameras
I have a agfa karat prontor-svs camera that belonged to my...
Loading problems.
Repair Service
Find Film Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
