Question about Nokia 6111 Cellular Phone
How to get my password in my mobile using bluetooth
How to get password when used bluetooth to my mobile
  • 30 Answers
Just press 1 and get the other person to press 1 and there u have it your connected and u can send items :)
Posted on Jan 10, 2009
I use this code'*#9990 in my nokia 3110c mobile
Hi, your problem is need to reprogram your cellphone or try this also maual reformat to your cellphone just dial this *#7780# and default password nokia 12345.but before you that reformat you need to back-up your files to memory card and save your contacts to sim memory.after you that the cellphone is back to normal setting .i wish that i help your problem.thanks
Jul 23, 2011 | Nokia Lands Phones
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
I can't Install Java Games i my Samsung A767 ...Its always Says "Unsported Files"
hi i think u might have directly copied the games to ur phone's memory card via data cable doing so may result in the phone saying unsupported files but since ur phone is java supported and the games will work for sure u can install the games via bluetooth enabled laptop or even u can use a bluetooth dongle to install the games in ur mobile.To install the games in ur mobile via the dongle follow these steps:-
1.first plug in the bluetooth dongle in ur system and ur PC will detect it,as soon as it detects the device go to the START menu PROGRAMS ->ACCESSORIES->COMMUNICATIONS->BLUETOOTH TRANSFER WIZARD and click on the ur system bluetooth wizard
2.switch on ur mobile bluetooth and search for any paired device u will receive a prompt message as soon as ur system detects the mobile and will ask u to enter the password type the same password which the system will generate and ur mobile will be paired u can then select a game file and send it in ur mobile from the PC via the dongle as soon as the file is copied u will receive a message in the mobile to install it type yes and there u go the game will be installed.
u can also try using another phone switch on the bluetooth device of the other phone and copy the file in the targeted phone via the bluetooth .was this useful to u if yes pls do rate my solution and u can also send ur views via the testimonials thanx fr visiting fixya
with warm regards - bonefirediv.
Apr 18, 2011 | Samsung Propel A767 Cell Phone
How to send a ring tone from msi notebook computer to nokia mobile by using blue tooth
Hi
I believe that you have to activate the bluetooth on your laptop by pressing the FN+F11 keys together
this should bring up two different circles on the screen one is for the wireless and one is for the bluetooth
then you have to activate the bluetooth on your nokia by going into the settings of the nokia and turning bluetooth on
then go back to your computer and right click on the ring tone
go down to bluetooth and go over to search other devices
hopefully it will then find your mobile bluetooth
and will ask for a password possibly
i did not know my password probably because it hadn't been set up
so i put in 0000
then it will ask it you can connect to your mobile
and you have to tell you mobile to accept
then put the same password into the mobile when it asks for it
it will probably also ask you if it can connect automaticly so i clicked yes
hopefully it will then send to your mobile
and i believe its a similar method to send from mobile to laptop
good luck
hope this was useful to you
Mar 07, 2011 | MSI Wind U100-030US Laptop
How i access internet in linux rhel 4 by my motorazr v3i
But there is a software i would personally recommend to you.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
  1. connect to mobile devices by IR, bluetooth, USB Cable
  2. Send and receive files between computer and device
  3. Access Internet from Device by Dial Up Networking
  4. Browse files on Mobile device
  5. Mount the mobile device on a user specified mount point or communication port.
    Usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
  6. Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  7. ability to connect to any locked/unlocked USB Internet Modems (Zero Devices)
  8. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
Sakis3g Homepage may not specify anything about connecting a mobile phone to computer and using it as an Internet Modem, but trust me its possible. Meanwhile I'm posting this by using DUN with the help of this script.
  • Just Run the script
  • choose Connect
  • Select Bluetooth
  • It will search for a new bluetooth device
  • Once your phone is detected, Select it and press ok
  • when it asks for APN (Access Point Name) provide it
  • When it asks for user name and password, Provide it. If your service provider do not need any username and password to access internet , Don't just leave it as blank (Program doesn't accepts empty user name and password. you just press space and enter)
  • Once all necessary informations are entered program may simply closes. Don't worry your connection manager will show this new connection entry.
  • To Disconnect the connection , you can select Disconnect option in Sakis3g.
hope this will help you to solve your issue.
Feb 22, 2011 | Motorola Mobility RAZR V3i Cellular Phone
How to connect htc touch p3452 to laptop as modem to connect to the internet using bluetooth.
you should have a inbuilt bluetooth or external bluetooth for connecting your HTC mobile to laptop. If you have inbuilt bluetooth then just open the bluetooth software and turn on bluetooth on your mobile also. Pair both devices it will ask you to provide a passcode provide 1234 then it will prompt for password on your mobile enter 1234 and follow the instruction it will connected to internet. If you have external software then download the bluetooth software and follow the same steps as in inbuilt bluetooth.
May 17, 2010 | HTC Touch P3452 Smartphone
Hi... I am using dell vostro 1510. I can see bluetooth sign on my laptop. but unable to use bluetooth. Please help me to use bluetooth
U can connect your system to internet using ur mobile phone through bluetooth.For this u need to set Bluetooth Personal Area Net(PAN)or use ur phone as dial-up modem.Check information of ur mobile to see if it can support either of these methods.Once the PAN is set, u can use net .If ur phone could be used as modem,do following to connect to internet.
Make sure that ur phone is paired with with ur comp.For more information,see Set up a Bluetooth Enabled Divice.
2.Click to open the connect to Internet Wizard.
3.If u already have Int.connection,Click Create new connection any way.
4.On the "How do u want to connect",Click "Dial-up"and follow the steps.Be sure to select ur phone.
5.On the "Type the information from ur Int.service provider(ISP)" page,in "Dial-up phone no." type ur phone no. or carrer no.
Contact ur mobile service provider to get required ID,Password,carrer code or phone no.
Apr 10, 2010 | Computers & Internet
Lost instructions how to pair with my phone
Bluetooth technology is a way to boost your mobility when talking on the go. It similarly provides a wireless network for transferring files and pictures that you have acquired on a mobile device. Enabling and using this function can be beneficial whether for business or for pleasure.
  1. tep 1 Select from the menu "Settings" --> "Connectivity" --> "Bluetooth." This will bring you into the Bluetooth menu function, allowing you to configure your Bluetooth technology. In this menu, you'll find an option to turn Bluetooth on or off. Select "on."
  2. Step 2 Look for devices on the mobile phonemag-glass_10x10.gif that will be compatible with a Bluetooth device. There is a menu option to seek these devices. If a device is listed on the menu, you have the option to pair this device with your mobile phone. To do this you'll need to enter your security password. This is generally created when initially setting up your mobile device.
  3. Step 3 Check for the visibility option. The phone does have an option to either make your bluetooth device visible or invisible to other Bluetooth and mobile devices. It's your decision to remain private or broadcast your signal.
  4. Step 4 Use Bluetooth for data transfer. Once connected, you'll be able to transfer calls to your headset, transfer photos from your cell phone to your computer, transfer photos from your computer to your phone, and transfer files back and forth. Ensure your invisibility when transferring sensitive information to avoid hackers and losing information to other Bluetooth users.
Nov 15, 2009 | Nokia 2760 Cellular Phone
Need bluetooth headset password
Default password is 0000 (4 zeros) Instruction Manual is here if you need it; http://www.sonyericsson.com/spg.jsp?cc=global&lc=en&ver=4001&template=ps1_1_2_2_1&zone=ps&lm=ps1_1&pid=10406&fid=41312&esi=true Best of Luck.
Sep 24, 2007 | Nokia 1100
Nokia 6111 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
