Question about Zephyr AK8100S Kitchen Hood
Changing the lightbulb on an old Pryne range hood
On the inside of the hood in the far left and right corners are little push buttons that say "push to clean" but I can't seem to release anything - the light is "under" a panel that's flush w/ the top of the hood next to the fan and I think the hood has to come down somehow to get tot where the lightbulb is - thanks!
4 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
SOURCE: range hood is making noies
I called Savona and they said this problem is due to the blower wheel being off balance and they suggested a new motor assembly. I had to purchase a new switch assembly 2 years ago. I cannot recommend this brand/model.
Posted on Dec 09, 2009
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
Can't find the secondary release for the hood on 1997 Jeep Grand Cherokee.
I thought I might be able to find you an owners manual online but there aren't any free ones.
Get a flashlight and lift the hood as far as you can raise it. Shine the light in and look for the hook. They are usually a little off centre to the left or right. The catch may pull left or right, or there may be a small three finger pad attached to the underside of the hood which you push up.
Let me know how you get on by posting as a COMMENT to this post.
Apr 03, 2016 | 1997 Jeep Grand Cherokee
Who carries REPLACEMENT' PARTS for PRYNE stove hood looking for a LIGHT SWITCH
the distributor of the brand of equipment you have
you can try these websites for more infomation
www.ask.com/
www.searchfiles.org/
www.wikipedia.org
www.infolinks.com/
/where is pryne distributor business information
/location of service providers of pryne equipment
/contact repairman for pryne stove hoods
Apr 21, 2015 | Kitchen Ranges
Electrolux PLHV42P8CC/two lights working two out and replacing bulbs does not fix the issue
Good Afternoon Rick,
I see that you are having trouble with the front right and back right halogen lights not working on your Electrolux range hood, model# PLHV42P8CC. I also see that you have heard of testing and replacing the transformer inside your appliance. I suggest contacting an authorized technician. It could possibly be something other than the transformer or it is possible that it is the transformer and something else that is causing the right side lights to not come on. Hope this is helpful.
-Best Regards-
WP
Apr 16, 2014 | Electrolux EFC90244X Kitchen Hood
How do i acess emerson pryne range hood to change bulb
Mine has a button under the hood on the rear right side (against the wall) that says, "Push to clean." When I pushed it and another similar one on the left side, the bottom of the hood swung down on hinges at the front. Going around the side and looking behind the section that was hanging down I could see all the innards of the hood, and could access the light bulb.
May 28, 2013 | Kitchen Ranges
Where to put in gear lube
With hood raised look to the far right in the corner. You will see the resevoir to the left of the resevoir for gear oil. The resevoir for gear oil is smaller & sits right in the right corner. The cap has a raised button on it & there's a round floating disk inside.
Dec 04, 2012 | 1991 Geo Prizm
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
I am trying to replace a burner on my amana smoothtop electric range. I have removed the three screws above the overn door (inside). The top is loose but something seems to still be holding it. Any...
most ovens usually have 2-3 screws located along bottom edge of the smoothtop in the front..check the far left and far right corners in the front /if all screws are removed,you may need to pull slightly forward then raise
Mar 06, 2010 | Amana AER5715QAS Electric Kitchen Range
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr AK8100S Kitchen Hood Logo
214 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
