Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
All lights flashing, Reset code wanted?
All lights flashing, replaced ink collection pads, need reset code to start working again!
The answer to my problem was to download ssc service facility it not only resets my reset problem, it also resets inks as well. Download is free and i rate it first class. It covers many epson printers.
Posted on Dec 22, 2008
Cx7800,epson
All lights flashing isn't something you can "reset". Are the lights flashing alternately, or together? These are different errors.
Alternating means that the printer thinks the "waste ink pads" are filled and need to be replaced (costs more than a new printer). You can reset the counter, but then you run some risk that the waste ink will overflow your printer onto the surface where it sits. messy.
The SSC utility will help you reset it if that's what you want.
SSC Service Utility for Epson Stylus Printer
Apr 13, 2015 | Epson Office Equipment & Supplies
How to reset a printer due to printer error message
If the error code on your computer says something about "parts are at the end of life", or if the lights are flashing alternately, there's a reset for "full ink pads" available. Epson dumps ink when you clean the print head into a pad in the bottom of the printer. Ideally, that needs to be replaced and the chip that counts the ink reset. Unfortunately, the labor cost to replace the pad is more than replacing the printer.
Sep 01, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Printer wont print ink keeps blinking on system
Hi
You not say what make of printer you got so not can gave you much help, because there is a reset code for different printers, the flashing lights you may be getting it because your, waste ink pads need changing and after this you need the reset codes for it but some times just the reset code will do the trick for it to print again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
Epson 1400 light flashing
Try powering off, unplugging waiting a couple and then powering up again, this will reset the sensor which is reporting a problem but it wont correct the problem
see page 64 in the user manual
http://files.support.epson.com/pdf/pho140/pho140ug.pdf
Sep 26, 2009 | Epson Stylus 1400 InkJet Photo Printer
Printer acts normal , no error codes, prints but no color
Without a computer, you can print a test page by holding the resume button until the green light flashes 2 times, one flash will do a printhead cleaning. If you enter the mode where you did the reset, and press the resume 2 times and the power button once, it will printout a page of printer data.
Sep 15, 2009 | Canon BubbleJet i560 InkJet Printer
Ink light and paper feed light are flashing alternatively, printer not responding at all !
I just had this same problem, and came here to figure out what to do about it. Turns out I had the CD/DVD tray in the out position, so all I had to do was flip the switch to stow it and the flashing lights stopped. Maybe it will work for you as well.
Aug 22, 2009 | Epson Stylus Photo R260 InkJet Printer
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Jan 24, 2009 | Epson Stylus Photo 810 InkJet Printer
Epson c70 problem
Re: Epson C70 Problem by Denny Conway (12/18/03 9:05 AM) reply + / - Aspah:A Service Error where all LED's/Lights are blinking at the same time,is normally a Maintenance Request Error, which is actually a Waste InkPad Overflow Error...JUST SO YOU WILL KNOW: On most Epson's, while theprinter is in this error condition, it disables all operations,including data communication. Normally your remedy is to replace theWaste Ink Pad/Pads with a new one/ones and then reset the InternalWaste Ink Pad Counter. If you just reset the counter and don't replacethe pads, then your printers old pads will eventually overflow andnormally start leaking ink out the bottom of your printer. You may wantto try doing a general search on the "fixyourownprinter.com" printerrepair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.You should be able to find quite a few references listed in the lastsix months and most included web-site links, for possible help on thereset procedure. Some also list links where you can purchase a SERVICEMANUAL, in case you want to try and do the service yourself...GoodLuck! Denny Conway...P.S. THIS INFO POSTED BY "WES" MIGHT HELP: Wes12/07/2003 13:57:30 To see what's involved in servicing the waste inkpads try this http://www.epsonhelp.web1000.com/wip.html ...IF you just want to reset the wate ink counter you can use this program http://inkjetprinterhelp.us/epsonSSC.html.Resetting the ink counter will stop the lights from flashing butcleaning/replacing the ink pads is recommended. ...OR... Tim H12/10/2003 2:46:24 Subject: Epson Reset Program Download Location.after a long search for a reset program for waste ink, without paying,i found it. goto: http://inkjetprinterhelp.us/sscserve.exe ...please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html ...p.s: this program has other features as well.
0.gif Re: Epson C70 Problem by Jim (12/21/03 4:10 PM) reply + / - I have just installed colour cartridges and a black cartridge into my C70.
Myproblem is that the black cartridge is not being recognised and I aminformed by the printer that there is insufficient ink in the cartridgeand a need a new replacement. The black cartridge that I have used is agenuine epson cartridge.
I have been informed by epson help linethat either I need to install a new new cartridge or that my printerneeds to go to Epson for a maintenance check.
I cannot afford another new ink cartridge nor can I afford the return charges and maintenance bill from epson.
Can you help?
0.gif Re: Epson C70 Problem by Wes t.gif (12/21/03 4:47 PM) reply + / - Theonly two option I can think of is to return the ink cartridge asdefective or you can trick the printer into accepting the cartridge.
Youwill need to download the SSC Service Utility and click on the "ResetCounters" tab and then click the "Reset Black" tab to reset the blackink cartridge. The only problem is you will need to reset or freeze theink cartridge.
You can get the SSC Service Utility here http://inkjetprinterhelp.us/epsonSSC.html
I hope this gets your printer going again.
Jan 02, 2009 | Epson Stylus C70 InkJet Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
660 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
