Question about Denon DN-951FA CD Player
Denon DN951FA CD cart Player How to change from 110V to 220V
Hi
I have a Denon DN951FA CD cart Player. The instructrion on the case shown that it is available for 120V , 230V and 240V. It is now in 120V but I want to change to 230V. Change voltage must follow the manual' instruction. However, I don't have the user manual. Would you please tell me how to do cos I need to use it in 230V later. Thank you very much!
Regards
Ken
5 Suggested Answers
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
Posted on Feb 20, 2009
petraman7
  • 1175 Answers
SOURCE: Denon 5 disc CD player pauses intermittently
Hi...
1st off , what I do with CD players is clean the rails that the laser assby runs on and treat the rail surface w/ liquid silicone.
Next pull all the cables to the CD assby and reseat them.
Clean the laser lens w/ pure alcohol and swab off till dry.
If there are any adjust pots , note where theyre set, rotate them a couple times and set them back to original set point.
You might be able to get the service manual at
www.free-service-manuals.com (14.00 for 3 months)
or www.stereomanuals.com
Posted on Apr 13, 2009
projdoc
  • 2237 Answers
SOURCE: hello i have a denon dn-650f cd player and i need
it's called an optical pickup and try mcm electronics. www.mcmelectronics.com
Posted on Dec 14, 2009
Testimonial: "thanks very much"
What could happen with CD player switching on power supply 220v instead needed 110v?
Feeding it with twice the voltage it needs to work on?
In the best case, only a fuse has blown. Worst case? The whole power supply has had a to high voltage, before the fuse blew. All components will be aged and can give up in a few hours, after the fuse is replaced, or in a few months.
It also could be there are already some defect components in the player.
I wish you luck and hope only the fuse needs replacement.
May 25, 2014 | JVC Audio Players & Recorders
I have a pro cut 25 i would like to change it from 110v to 220v
The pro cut 25 will run on ether 110v or 220v without changing anything. I made a 220v to 110v adapter. It works well and if I want to run it on 110v it will still plug right in.
Dec 05, 2013 | Lincoln Electric Plasma Cutter, Pro - Cut...
Makita Dc18rc from 110v to 220v
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
May 17, 2013 | Drills
110v or 220v ?
That would be a 220v dryer...virtually all electric dryers are 220v.
heatman101
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
Error code E-99 cd won't load. Denon cd player for cars.
Hi. this denon error code is signaling an issue that concerns the loading deck and optical lens assembly. in this case, the entire assembly will need to be replaced asap if possible
Jun 19, 2009 | Denon DN-S3500
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
DC18RA from 110v to 220v
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Nov 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Denon DN-951FA CD Player Logo
446 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
