Question about Hotpoint Aquarius WF210 Front Load Washer
How do I find and clear the filter in Hotpoint Aquarius wf210?
This is a front loader 6kg machine. Sure machine must be clogged with dog hairs from his bedding etc. Dont know how to locate filter and clear it
  • jan1860 Dec 21, 2008
    Thanks very much for your help! Would never have worked this out for myself!
    Problem Solver:
  • 12 Answers
Pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
Posted on Dec 21, 2008
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 filter location?
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Require a manual for Hotpoint Aquarius WF210 washing machine
You cannot download a repair manual on line, you have to purchase them from Hotpoint,
However, if it is a user manual you require, then go to:
WWW.HOTPOINT.CO.UK
Click on after sales, and then on download instruction books, put your model in the box, and then you can download to your computer. or to your printer.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Leaking washing machine
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
341 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
