Question about SanDisk Sansa e250 MP3 Player
Dos error dont play mp3 . all of them same error ''dos error''
  • 8,596 Answers
Reformat your player. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
If you still get the same error: Reformatting through your computer usually involves plugging the player into the computer, double-clicking on My Computer, right-clicking on either the icon of the mp3 player or the generic drive letter that your computer has assigned to the player, and selecting “Format.” FAT32 is usually the correct option, but I would always consult the manufacturer/user manual first to be sure.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
Jan 27, 2011 | Freestyle Audio MP3 Player
I have it almost installed but before i can play the game my screen changes resloution and magnifies my windows then i get an alert box telling me that the organ trail game cant be installed then it closes...
Ahh i see.... Starting with windows 2000/XP. Windows no longer supports DOS... Im kinda sad about that myself D= but it doesnt end there for you my friend. Organ trail is a great game.
My tip is for you to get a program called DOS box from source forge. Simple google DOS BOX. Install the program and run the program from within dosbox. If you dont know how to run dos box simply drag the EXE you are trying to run into the window. Give it a try and it will work trust me. GL in the game....
Feb 19, 2010 | Computers & Internet
Im having problem wit my mp3 its says error i dont know what to do
just try to update the software of your mp3 .
good luck .
Jan 26, 2010 | GPX MW249 MP3 Player
My transecnd tsonic does not fomating with fat32
have you tried formatting using ms-dos?it works many a times when windows format shows an error...the command is
format x: /fs:fat32
where x: is yout tsonic...
If that doesnt work,try this 1.download the appropriate firmware from here  2.press and hold reset button for 2 seconds  3.run the firmware updater  4.press and hold "play" button while connecting to system.  5.the updater will detect the player and it will upgrade the firmware.
Sep 26, 2009 | Transcend T.sonic 610 MP3 Player
MP3 player not working and cannot be formated or opened anymore
you can format it form pc and use dos command . go 2 run and type cmd when open dos then type format and type ur mp3 drive such h/g. then type : and press enter
follow this command
format g;
Aug 03, 2009 | Audio Players & Recorders
Divide Overflow Error msg
well, in DOS the game Wizardy - Bane , still shows up the divide error msg
how ever, i decided to try to run the game in windows 3.11
and it worked!
i am happy.
so, this really wasnt a true fix, but more of a work around
Dec 25, 2008 | Microsoft Windows 98 for PC
Dos error
error! check upgrade file. help
Aug 26, 2008 | Audio Players & Recorders
MP3 PROBLEM
FORMAT IT
GO TO
MS-DOS
RUN>CMD
FORMAT G:
Jul 08, 2008 | Insignia NS-DV2G MP3 Player
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Jan 29, 2008 | Transcend T.sonic 612 MP3 Player
Computer system does not detect the player
Print Page - MS-DOS Tutorial You want to use a diskette but you're getting a "unrecognized file system" or similar error. Or, you're in the recovery console and you need to wipe your.
MS-DOS error messages If there is no disk inside the computer, this could be an indication of a unrecognized hard drive, unformatted hard drive, or hard drive with missing system.
Good Luck, Please dont for get to Vote.Thank You.
Dec 19, 2007 | Creative Labs ZEN Vision:M Digital Media...
SanDisk Sansa e250 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
