Question about Frigidaire FGF337EC Stainless Steel Gas Kitchen Range
OVEN WILL NOT STAY LIT
HAVE A FRIDGADARE GAS RANGE THE OVEN SOMETIMES LIGHT SOME TIMES DOES NOT WHEN LIGHTE THE OVEN DOES NOT STAY ON
  • 42 Answers
Sounds like you have faulty ignitors . replace the ignitors and you should be good to go. if you post your model # i can get you a part #
Posted on Dec 21, 2008
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Oven wont stay lit
If you are talking about the little flame that is supposed to be burning at all times then you need to go to a hardware store and purchase a thermocouple. It is a small copper tube that sense's the flame. When working it will constantly burn a pilot flame so that when you turn on the oven it will ignite the gas in the burner. Once the burner is lit it will stay lit until the oven reaches the desired temperature. Replace the THERMOCOUPLE.
Sep 09, 2011 | Belling Solitaire G755 Gas Kitchen Range
Why won't my roper gas range (FGS337KQ) stay lit? The oven will light for 30 seconds and then shut off. Ignition is working.
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Oct 30, 2009 | Roper FGS337 Gas Kitchen Range
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
Oven will not stay lit,
Sounds to me like a bad thermal fuse. Call a tech in to replace it.
Apr 11, 2008 | Whirlpool GS460 Gas Kitchen Range
GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FGF337EC Stainless Steel Gas Kitchen Range Logo
203 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
