Question about Sony DAV-FC7 System
My DAV-FC7 System squeals loudly.
System squeals loudly for 5 minuted when first turned on and then gradually quiets down.
  • 3 Answers
If you can, use the digital optical connection....I had the same problem and switched to the digital optical connection and that worked for me....no more whine.
Posted on Dec 27, 2008
My system power is intermittent. Won't turn on at times.
Make sure all cords are properly connected if so then their might be a problem with the wiring... try moving the wiring up and down, and see if the power turns on when you do that.....
Jan 09, 2011 | Sony DAV-FC7 System
Can i watch regular tv and use the dav-fc7 as audio?
just run the "line audio" not your speaker audio out from your tv to the aux or dv/cd input...
on your dav-fc7 it will sound great! just turn the tv audio sound down at the set.
Dec 03, 2010 | Sony DAV-FC7 System
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Sony DAV-FC7 squeals
I had the same problem....but it kept taking longer and longer for it to quiet down, then eventually it just kept whining and I couldn't take it anymore...I had to stop using it for tv and only used it for DVDs (it didn't whine on the dvd function). I was going to get rid of the unit because my old tv died and I had to buy a new flat screen high-def unit, which needs a surround system to do it justice. I then noticed the digital optical connection on the Sony DAV-FC7 as well as my new Direct TV HD-DVR. I bought the optical cable for about $15 and hooked it up....and voila...NO MORE WHINE! If you have the optical connection option....try that route...it might work for you as it did for me. Good luck
Dec 21, 2008 | Sony DAV-FC7 System
Dvd's wont eject from my sony dav-fc7
because of bad loading mechanisum.
its belt melted i think.can you observe the motor runing sound the inside of player.
nuwan...
Nov 22, 2008 | Sony DAV-C770 System
Sony AV System DAV-FC7 cannot turn on
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
-Sathish
May 13, 2008 | Sony DAV-FC7 System
Sony DAV-FC7
the last sent DVD was bad i think
FAC-FC7 DVD player is locked and the Standby indicator flashes
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
Nov 12, 2007 | Sony DAV-FC7 System
Sony DAV-FC7 System Logo
288 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
