Question about Jura Capresso Impressa E9 Espresso Machine & Coffee Maker
Lost instruction manual
We have a Jura  E9 and lost he instruction manual when we moved. we need water filters and cleaning tabs and need to know what to order.  Can you please send instructions via email or regular mail.
dcmawicke@mac.com
Daniel Mawicke 230 Putting Green Road Trumbull, CT  06611
  • 4 Answers
check out this link:
http://capresso.com/pdf/inst_e_series.pdf
Posted on Feb 21, 2009
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Jura fs50 - "Decalcify".
If you read the instructions in the manual (Page 6) it describes how to descale (de-calsify) the machine. You use a vicious liquid to be used with great care. If you lost your manual go to http://www.coffeesolutions.jura.com/home_coffeesolutions_x/service_support/download_guidelines_jura_impressa_s9otc_english.pdf
Mar 23, 2014 | Coffee Makers & Espresso Machines
Jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
Nov 29, 2011 | Jura Capresso Impressa E9 Espresso Machine...
We love our model E9 coffee maker. However, our coffee has been bitter. In South Florida our water isn't the greatest, but I use double-filtered tap water, and also bottled water. We also use good...
t is most likely the coffe you are using,I would suggest you try different roast from different brands until you find what you like..for axemple Lavazza coffe from Italy has all kind of different roast.
good luck
Aug 25, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Aug 02, 2008 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso Impressa E9 Espresso Machine & Coffee Maker Logo
365 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
