Question about Dell AMD 386/33 Desktop Computer 333S/L Motherboard
Dell c400 upgraded to xp now it won't boot up
I took out the HDD and put it into a toshiba laptop and formatted it and then loaded xp onto it. Starts fine in the Toshiba but not in the Dell.
1. Still asks if I want to fun windows 2000 or XP Pro
2. After choosing XP Pro it asks me for different safe modes
3. After trying all the options, the same thing happens each time. The computer shuts off and I start all over again.
What is different between the Toshiba and the Dell C400 that is stopping XP from running?
P.S. Have not loaded the Dell c400 drivers yet as the computer won't start
Thanks
  • 8 more comments
  • wdiddy Dec 21, 2008
    I think I did a full format. I did it before I setup XP with the blue screen, is that a full format? It did the whole hdd. What info do you need?
    1. On startup still asks what OS I want to run 2000 or XP
    2. Choosing 2000 doesnt' work as it's missing
    3. Choosing XP Pro it asks for different safe modes
    4. Tried all safe modes and regular but it won't start up. Will just shutdown afterwards
    5. Seems like the Dell C400 is looking for something else to start up
    6. As you know the C400 doesn't have a built in CDRom that's why I had to take out the HDD to format it. Tried running XP directly from portable CD drive but got a bunch of errors on loading and then Dell wouldn't start up at all. Was just able to get the BIOS setup screen, but couldn't but up at all, that's why I did the format.
    Hopefully someone can help now
    New info, when I formatted the HDD I created 2 partitions. I did a boot logging startup and got stop code 0000007B which means inaccessible boot device. Read that it could mean something to do with partitions. Will reformat the drive and make only one partition and see if that does it.
  • wdiddy Dec 22, 2008
    Okay I loaded xp again this time with one partition and it still didn't work, same problem. I can't run it from the cd drive as it requires a driver to run so I can't use it until I get an OS to work. Is there some kind of registry edit that I can do?
    Found this on this forum, does this sound like it will work, it's quite a bit to do and if it isn't gonna work I would like to know now. Thanks
    The only way to do this is to pull the hard drive, and install windows
    on a computer that has a cd rom drive. Install windows on the other
    (laptop) and do not install any additional drivers.
    install the ethernet driver if needed and run all the windows update.
    Download all the drivers from dells website for the dell c400
    Once the drivers are all unzipped, note down all the paths it unzipped from to a text file.
    example: "c:\dell\drivers\audio"
    example: "c:\dell\drivers\audio\XP"
    example: "c:\dell\drivers\chipset"
    example: "c:\dell\drivers\chipset\something..."
    make sure to get them all and do not include the ""
    once you have all that information in a text file, sepeate each path of
    driver with a ";" and arrange it so there all on one line.
    example: c:\dell\drivers\audio;c:\dell\drivers\audio\XP;c:\dell\drivers\chipset;c:\dell\drivers\chipset\something
    again make sure to not include the ""'s....
    now copy the entire line
    go to start | run | regedit
    browse to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
    modify the DevicePath by double clicking
    do not delete anything that is in there, instead add a ; to the end and paste the rest
    this will point out all the folders and sub folders for all the dell C400 drivers
    go to microsofts website and download the latest version of sysprep
    run sysprep and leave all the default settings just to make it simple
    make sure to choose mini setup and shut down check boxes
    once complete the computer will strip any unique sids and create an image for deployment.
    you can then pop in the drive to the dell c400 and let it self install
    xp with all the drivers you have preloaded and all the windows updates
    installed without the cdrom or floppy drive, this is the best free
    solution to do this.
    An external cd drive needs to have a driver installed first for it to work, doesn't it. That's the reason I'm having this problem, I can't load via cd because the hdd doesn't have the driver beforehand. Is there a solution to this problem? Can I load a driver onto a formatted hdd and will the laptop then notice the external cd drive?
    This is a small laptop that can't fit a drive into it. It has to have an outboard drive.
  • wdiddy Dec 29, 2008
    Thanks crayzee it worked. Took me some time as I'm not familiar with Fdisk and had some problems. Finally did it, only took about 100 hours LOL
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    the problem that you may be having is that you are loading windows on 1 machine and then trying to "finish" on another .. The hardware is different on both machines and it loads different drivers. Sometimes that process works (rarely), but I see this as being the "bottom line" problem. You need to really get yourself a CD drive for your 400 and load all from there.
  • melissa titus May 11, 2010
    need more info
  • Jay Glendenning
    You did a full format?
  • 837 Answers
Its not gonna work, unfortunately. You cannot load it on a machine then take that drive out and put it on another. SOMETIMES this can work but only if the chipsets are the same or "similar" .. But what %'age of similiarity is required is ... well .. a mystery
Posted on Dec 22, 2008
  • 1 more comment
  • Jay Glendenning
    Jay Glendenning Dec 22, 2008
    Thats alot of work for a maybe .. a cd drive is less than $50. Is it worth all that time and it still doesn't work ...
  • Jay Glendenning
    I don't have any "personal" experience with Dell C400 but I would imagine that in the BIOS there is a setting that would allow you to use the external CDROM as a boot device.
    When you bought this unit .. just out of curiosity .. why did you opt for no optical drive (i.e. cdrom, dvdrom)?
  • Jay Glendenning
    I havent tested this process but I did evaluate it visually and it should work .. click here
  • 67 Answers
You have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
Posted on Dec 21, 2008
I cant format my C400 with a pen drive
If you're tryng to format the HDD on a Dell latitude C400 (or install an OS), this thing will not boot to any USB devices (flash drives, pen drives, external USB cd-rom drives, etc.) - just ain't gonna happen since the BIOS doesn't support such boot devices. The only thing it'll boot to is (1) docking station, and (2) a Media Bay optical drive.
Sep 01, 2011 | Dell Latitude C400 Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I have dell laptop latitude c400. Ican't reinstall the windows xp from external dvd writer. How can install the windows xp pls tell me?
This laptop will not give you an option to boot from a usb device or even from an external cd rom/dvd. You need to do a network install only for this particular model DEll c400. It is a long process and requires some skill of setting up a RIS server. You will also need a switch or hub to connect your laptop to it. Once your server is setup with dns, dhcp and ris you need to do a network boot and install the os. Get in touch with a professional to do it if your not familiar with this. I tried calling dell as i had a similar issue and they couldnt help me over the phone so they sent over a technician. Technician tried in vbain including removing my hdd and installing the os on his laptop and then putting the hard drive back into mine. It still didnt work. I then researched the net and figured out the only way to do it was via a remote installation.
Jun 13, 2010 | Dell Latitude C400 Notebook
Dell latitude c400 model PP03L, how to install xp no cd/dvd and don`t see usb from bios
If you already have an USB flas bootable with XP on it, plug in into the laptop, and when the laptop starts, press F12. Then you should select that the computer should boot from USB. If this won't work, try to attach an external DVD\cd unit.
Nov 04, 2009 | Dell Latitude C400 Notebook
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
Dell latiyude C400
The system is in a reboot loop. Possible causes are:
Corrupt installation of Windows
Bad Hard Drive
Bad RAM
Bad Motherboard.
Try booting to the Windows XP CD, see if you can access recovery console and run CHKDSK /R If that doesn't resolve, boot to the resource CD, and run diagnostics on the HDD
If you can't, boot to the XP CD or Resource CD, try removing the HDD and booting to the CD. If the system boots then, the HDD is most likely bad.
If you can't boot to any device, try RAM modules individually, see if system boots with only 1 module installed. If no change, then motherboard is bad. On a system this age, I do not recommend replacing a motherboard as it is not cost effective
Jun 22, 2009 | Dell Latitude C400 Notebook
Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
Jan 29, 2009 | Dell Latitude C400 Notebook
Dell c400 loading xp
Did you sysprep the system?
You should only load the drivers that are needed to make the system run the basics. Don't worry about the network card unless you wish to install windows updates. I recommend just installing the OEM version of XP and modifying the registry to add drivers.
HKLM Software Microsoft Windows CurrentVersion "DevicePath"
Leave whatever is in there and add all the drivers to that folder. Make sure to include the motherboard drivers for the Dell laptop followed by all the other drivers. Some drivers will contain sub folders and you need to specify those as well spaced out by semi colons.
This should be all pasted in the devise path and it should look similar to this.
%SystemRoot%\inf;c:\dell_drivers\C400\Audio;c:\dell_drivers\C400\Video;c:\dell_drivers\C400\Video\XP_32; ect ect ect... if there sub folders in the drivers that are zipped, unzip them to the directories that you created on the root of C.
Once you have finished downloading all the drivers and modified the DevicePath registry key then download SysPrep from microsofts website and select Mini Setup and Shut down check boxes. Once the system shuts down then put the drive into the other laptop.
The system will be setup to install XP on the C400 with the drivers you included from the registry and the paths you pointed them to pole. On newer systems with Sata drives and other specific types of hardware like RAID you will need the hardware ID and adding that to the answer file for sysprep but that is way more complicated! For a DellC400 you will not need to do that.
Dec 22, 2008 | Dell Latitude C400 Notebook
Format
you need to go in to the bois and click on the boot up menu then the 1st boot should the usb then it will pick up your xp disk
Nov 19, 2008 | Dell Latitude C400 P3 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Computers & Internet Logo
1,081 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
