Question about Maxtor DiamondMax Plus 9 120 GB Hard Drive
Hard Drive I have a new hard drive. It is second hand but new to my computer. When i turn it on (the computer, with the hd correctly in) it makes a funny tune three times. Then it says oporating system not found. I try to install windows but when it has finished loading the drivers, it freezes and i get a blue screen saying "Your computer has been shut down to prevent damage to your computer) or something like that. Does anyone know what is wrong and how to fix it?
  • benofreke Dec 21, 2008
    that didnt work, i get a blue screen after the windows installation has finished loading, and the blues screen is the "Stop 0x00000007f"
    Problem Solver:
  • 11 Answers
Hi I use Maxtor HD's and IBM Deskstars also, one of my pc's has 4 500 gb SATA drives [not in raid mode] and have had some problems also.
If you are using 2 drives then one should be set as master and one as slave. Same thing goes for cd/dvd roms, master and slave, and use 80 wire ribon cables. If you are using just one drive and the settings in your bios, and master or slave and what drive boots up the machine.
if using only 1 drive set it to master [in SATA it does not matter you can leave them all as masters, and only if the cd.dvd's are SATA also, if not they have to be set up as master & slave, set the bios to boot from cd drive 1st 2nd is your HD and last is if you still use them a floppy. On boot with the OS CD in the drive boot the pc and it will start the instalation of windows, delete any partitions, format the drive [NTFS] NOT FAT OR FAT32, and you should be able to do a fresh instal. As with 2nd hand drives as they were used on another pc they have hidden files left on the drive [unless the person that gave it to you has prepared the drive to do a proper instal if not windows gives you the option to delete, create and format the drive, to be ready to continue to instal windows.
HTH
Zues
Posted on Dec 21, 2008
Hello, Recently I tried to back up my computer onto my EXT HD but it was not successful because of lack of storage size. Coincidintally, my EXT HD will not turn on. It all happened at the same time. I...
the problem could be from your USB. The USB of your computer might not be powering the drive.
Secondly, the hard drive wire that passes from the computer to the external drive.
Lastly, the Hard drive case could be defective and not make the drive power on.
Therefore, connect the external hard drive to another computer, in other to be sure whether the problem is from your computer's usb port or from the hard drive. This will let us know where to focus our attention.
Let me know what happens thereafter.
Take care.
Aug 15, 2010 | Computers & Internet
Disk Managemet says my hard drive "Not Initialized". Windows cannot see it in My Computer. How can I recover my data?
let me get this straight... you can boot-up and windows does start. So your system is seeing the hard drive well enough to get you into window, but once there it refuses to see the hard drive it is based on??? Or by some chance is there a second hard drive which you are attempting to access? If that is the case you need to #1 see if it listing in your bios menu which you can access during start up, but even before that you need to make sure that the second HD is jumpered to slave mode if your running off the second hookup of a dual IO cable, if on the other hand you have it plugged into the second plug on the motherboard make sure you have it set to master. If that is all set then.
#2 reboot your computer and log into your bios menu look to see if your HD is listed if not using your +/- keys once you have the first open slot highlighted use the +/- keys to run through you options when you see auto check your bios control legend on the bottom hit the button which activates it your HD should show up in that selection area.
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Lacie 1tb ext hd. drive does not show in disk
Your external drive has 2 parts, the hard drive, which is just a normal hard drive you would find in any computer, and the usb bridge, which connects the hard drive interface (either ide or usb) to the usb or firewire or esata or whatever. Sounds like one of these are bad. Does the computer see the bridge? it should show up as a mass storage device in device manager and the safely remove usb devices dialog. If not, then get a new enclosure for the drive. These range from 25-100 dollars. If the bridge does show up, take apart the enclosure and pull the drive out and try hooking it up as a second drive in your computer. If it works there, then you need a new enclosure. If not, then you need a new drive.
Dec 07, 2009 | LaCie Computers & Internet
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Hd may be corrupted
Yes, definitely you can buy replace with any 2.5" laptop hard disk make sure that you buy HD with correct interface, if you old HD is IDE then buy IDE hard disk , elsei if SATA buiy SATA harddisk
RATE THIS SOLUTION!
RNJ VINOD KUMAR
Sep 13, 2009 | Dell Latitude D600 Notebook
Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Replacement HD for RAID Array
you have a jbod you will need to do this right click on my computer select manage from the drop down menue under this option you are going to select disk management on the lower right it will list the hard drive if installed correctly.Initialize the drive and format it .
Good luck
Aug 29, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Hard Drive
Try installing the hard drive in the set up ops, Before you power the computer up hold the f2 down and start it up, Next in the setup you will see hard drive it should say auto detect or manual,,Just copy down whats on your HD. After you do that Hit f10 and save then restart your computer.
joe
Dec 20, 2007 | Computers & Internet
WD not turning
First enable the hard drive in bios if you havent already .Then if you have windows xp click right on my computer and select manage,it opens up computer mangement, then go to the tab called storage and on the sub menu of storage click disk management . You should see you 2nd/other hard drive (labelled disk 1 at the bottom if it is the second hard drive) make sure its your 2nd HDD ( Look at capacity in properties by clicking right on it) .Click right on the 2nd hard drive and select format press ok when the new window comes up and its finished.
Nov 15, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Maxtor DiamondMax Plus 9 120 GB Hard Drive Logo
246 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
