Question about Cherokee Jeep Grand - RBB AM/FM Stereo Radio w/Cassette Player and integrated CD Changer Controls
CAR STEREO NOT WORKING
I RECENTLY HAD A NEW STARTER MOTOR FITTED AND NOW THE STEREO IS ASKING FOR A CODE WHICH HAS BEEN REMOVED FROM THE MANUAL BY THE PREVIOUS OWNER I HAVE TRIED TO INPUT AS MANY CODES AS I CAN BUT ITS NOT WORKED AND I HAVE HAD NO MUSIC FOR OVER WEEK NOW CAN YOU HELP ME?
  • pauloouk Mar 06, 2009
    I PUT IN THE WRONG CODE IN NOW IT KEEPS SAYING WAIT 2HRS BUT ITS DRIVING ME MAD HAD NO MUSIC FOR 7MTHS
  • 78 Answers
Contact the maker of the deck.
I had the same prob',the maker gave me the code after supplying them with the model,and ser##'s,it worked!!
note;any knowing shop would place a small 12v powersupply to the batt cables before unhooking car batt,also most of the time,you are safe to unhook battery for 10min's to one day,before the security code "goes away"(every deck is diferent)
Posted on Dec 21, 2008
    Problem Solver:
  • 11 Answers
Hi
With the newer cars most radios have a theft deterrent device built into the radio, and if they steal your system it will not work in another jeep/car the dealer knows the unlock code, some charge to unlock the radio some don't.
That's why when doing electrical work on a car/truck etc. You have to have 12V DC power to the battery terminals all the time or you will loose the code and then only the dealer can help you unlock the radio.
HTH.
Zues
Ford Radio Code for FD500N Ser No. M372477
need to take serial no to ford garage they will help you out
Jan 19, 2015 | Ford Cars & Trucks
Can i fit a starter motor myself and how?
yes you can if you have some knowledge .
disconnect battery making sure you have radio codes before disconecting
take picture of wiring with camera phone if possible on starter or mark position and write down
remove wiring
mark starter position that is starter to housing to facilite installation of new starter
remove bolts from starter normally 2 or 3 bolts holding it in position
remove and fit in reverse order
Sep 22, 2011 | 2005 Kia Sedona
I have a old clarion factory fitted car stereo in my kia sportage 2000 model its asking me for a code can you assist thanks.
the new stereos are unlocked by an unlock cd.following are the options to obtain an unlock code for the stereo:
1-contact ur car dealer and ask him for the unlock cd.
2-go to some good car stereo shop and ask them to unlock the stereo. 3-if u r a wiz kid, wrie the model of ur stereo in google and search it for an unlock cd and burn it and insert it in the stereo.
Mar 11, 2011 | Clarion Car Audio & Video
Removing the starter
First you want to determine the reset code for your factory installed stereo system. The anti-theft system in place will shut down when you disconnect the battery cables. You will need the reset code for your stereo to remove starter.
Park your Honda Accord on a level surface, activate the emergency brake and place blocks behind the back tires for safety. Disconnect the negative battery cable with a terminal puller. Disconnect the positive battery cable. Raise the front end of the car with a jack for easier access to the starter.
Remove the starter motor wiring harness in 2.2L, 2.3L and 2.7L engines. In 2.2L and 2.3L engines, your next step is to find the bracket on the starter motor and disconnect the lower radiator hose. In 3.0L engines, you need to remove the Automatic Transmission Fluid (ATF) cooler.
Locate and remove the starter cable from terminal-B on the back of the solenoid (for all four engine sizes). Disconnect the black and white cable from the S-terminal.
Unfasten the two starter mounting bolts from the transaxle assembly. Remove the third mounting bolt at the back of the starter. Place all bolts and nuts in the baby food jar to prevent loss. Remove the malfunctioning starter.
Take your malfunctioning starter to the parts store with you. Aftermarket distributors remanufacture most of the starters they sell, so you can likely obtain a partial credit toward your new starter by exchanging your old one. Be sure that you take care not to damage the starter in transit, because the better condition it is in, the more you can get for it.
Purchase a replacement starter that has the same or higher cranking capacity (power rating) as the original starter in your Honda Accord. Also, match the bolt patterns, drive gears and electrical connections. Your owner's manual may list specifications or the auto parts technician will help you determine them.
Hope this helps
Mar 02, 2011 | 1996 Honda Accord
I HAD TO REPLACE MY STARTER ON MY 1981 HONDA GOLDWING 1100 . I AM HAVING TROUBLE GETTING IT BACK ON , BILL , I CAN GET IT REALLY CLOSE , BUT THAT IS IT .
Remove the Malfunctioning Starter
  • 1 Determine the reset code for your factory installed stereo system. The anti-theft system in place will shut down when you disconnect the battery cables. You will need the reset code for your stereo to work following starter replacement.
  • 2 Park your Honda on a level surface, activate the emergency brake and place blocks behind the back tires for safety. Disconnect the negative battery cable with a terminal puller. Disconnect the positive battery cable. Raise the front end of the car with a jack for easier access to the starter.
  • 3 Remove the starter motor wiring harness in 2.2L, 2.3L and 2.7L engines. In 2.2L and 2.3L engines, your next step is to find the bracket on the starter motor and disconnect the lower radiator hose. In 3.0L engines, you need to remove the Automatic Transmission Fluid (ATF) cooler.
  • 4 Locate and remove the starter cable from terminal-B on the back of the solenoid (for all four engine sizes). Disconnect the black and white cable from the S-terminal.
  • 5 Unfasten the two starter mounting bolts from the transaxle assembly. Remove the third mounting bolt at the back of the starter. Place all bolts and nuts in the baby food jar to prevent loss. Remove the malfunctioning starter.
  • 6 Take your malfunctioning starter to the parts store with you. Aftermarket distributors remanufacture most of the starters they sell, so you can likely obtain a partial credit toward your new starter by exchanging your old one. Be sure that you take care not to damage the starter in transit, because the better condition it is in, the more you can get for it.
  • 7 Purchase a replacement starter that has the same or higher cranking capacity (power rating) as the original starter in your Honda . Also, match the bolt patterns, drive gears and electrical connections. Your owner's manual may list specifications or the auto parts technician will help you determine them. Download a free owner's manual at Honda Service Express.
Install the New Starter
  • 1 Position the starter next to the transaxle assembly and replace all three mounting bolts. For 2.2L, 2.3L and 3.0L engines, torque the mounting bolts to 33 foot pounds (45 Nm) and the wire terminal nut to seven foot pounds (nine Nm). For 2.7L engines, torque the mounting bolts to 47 foot pounds (64 Nm) and the wire terminal nut to 6.5 foot pounds (nine Nm).
  • 2 Reconnect the wire cable to terminal-S and the starter cable to terminal-B. Be sure that the crimped side of the terminal end is facing out when reinstalling the heavy gauge starter cable. If applicable, replace the lower radiator hose (2.2L and 2.3L engines) and the ATF cooler (3.0L engines). Reinstall the starter motor wiring harness.
  • 3 Lower your Honda back to the ground. Reconnect the positive battery cable, followed by the negative battery cable. Turn the key in the ignition to see if your new starter motor functions correctly.
  • 4 Enter the anti-theft code for your stereo system and any presets
Aug 02, 2010 | 1981 Honda GL 1100 Gold Wing
Blaupunkt car stereo needs new code
try asking here
www.ukbookshelf.co.uk
as they offer free advice and codes , especially for these Bosch radios fitted in Suzukis
May 07, 2010 | Blaupunkt Car Audio & Video
My battery was disconnected for a new starter motor to be fitted - now it won't tune in. CD works but radio just hisses? I've checked aerial connections which seem OK. Radio lights up and looks like it...
Somehow your antenna has become disconnected. Check the back of the stereo and look at the ANT connection. Remove it and test continuity from the center to the outside antenna. Chassis is ground and most likely will not have a problem.
Jul 05, 2009 | JVC AM FM CD DET FACE CAR STEREO
Stereo issues
Not unless it was written down in there by the oridginal purchaser so you will have to write VIN# down and phone the dealer and they will be able to give you the code along with how to do this also it must be a factory sterio hope this helps
May 27, 2008 | 2001 Mitsubishi Galant
Remote starter installation - disabled Bose car radio
It could be the stereo has an anti-theft lock-out that requires a code to be put in after the battery is disconnected. Your manual should have the code and instructions on how to enter it, or the dealer can do it.
Hope this helps.
Dec 29, 2007 | Car Audio & Video
Car Audio & Video Logo
313 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Marvin
Marvin
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
