LG DV380 Disk error message
When I first turned the DV380 on, no language setup screen appeared. Now when I try to play a disk, all I get is a disk error message?
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
SOURCE: Disk Error Message
when my mp4 player says disk error i hook it up to the computer to try reformatting it, but when i hook it up it does not recognize or show my mp4 player is hooked up. What is my problem and how do i fix it?
Posted on Jan 25, 2008
  • 4 Answers
SOURCE: disk unkown error message
If other dvds play then try getting the same movie but from another supplier if it persists the check yo dvd if it uses a dvd ROM then replace it with anew one.
thanks
Posted on Apr 05, 2008
jaffa012001
  • 376 Answers
SOURCE: Multi Region Code LG DV380
Open Tray
Press 0 three times and when region menu appears select 0 then press pause
Posted on Sep 08, 2008
  • 31 Answers
SOURCE: PS3 Disk Read Error
PS3 is The amazing device by sony but it has some common problems like Disc read error, unreadable disc etc... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 03, 2009
A disk read error occurred
Click "Start" and "My Computer." Navigate to the "C" drive on your system and select the folder marked "i386." Find your "Winnt32.exe file and double-click it.
Press the "Enter" button.
Click "Launch Setup" when the Windows Setup page appears. When you click this choice and not the "Boot Legacy operating system" selection, you will not receive the "disk error" message any longer.
Adhere to the directions on your screen to finish the process of reinstallation.
hope this helps
Aug 12, 2012 | HP Compaq dx6100 PC Desktop
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
LG DP450 portable dvd player will not play dvds. No disk appears on the screen & these are new original disks which work in other devices.
This solution worked for me! My portable player would no longer turn the dvd, "no disc error". I bought a disc cleaner at a local office supply and manually turned it with my hand about 10 times. It works now!!
Jan 09, 2011 | LG DP450 Portable DVDDivX Player
Problem with setup
just extract the folder and then try to install it again
Oct 18, 2009 | Microsoft Windows XP Home Edition
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
Open Tray
Jul 03, 2008 | Televison & Video
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Unlock code for LG DV380
1. Open DVD tray
2. Press the '0' key on the remote three times, waiting about one second
between key presses. The 'Region Test' screen will appear on the TV. If you don't
get this screen, then power off/power on again and start over.
3. If the Region Test screen appears, enter '0' for all-regions.
4. Press pause to save and exit.
Jun 16, 2008 | Televison & Video
Disk unkown error message
thanks
Mar 30, 2008 | Televison & Video
CRAIG MP4 plus video player- disk error message appears.
make sure the songs you download are right for your mp4 player because Limewire only plays mp3 songs. so i would go on the internet and find a music site that has mp4 songs
Jan 28, 2008 | iLO (2 GB) MP3 Player
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
