Question about Aragon 28K MKII 2-Channel Amplifier
Loose knobs I've had this preamp for around six months, and although its sonic performance is ok, its build quality leaves much to be desired. The knobs are starting to loosen up, to the point where, just a few weeks ago, as I turned the power knob, the thing stayed in my hand! Upon examing it up close, I realize that there is supposed to be a tiny screw which fastens the knob to its post. However, the post on the pre's body has no perforation for the screw to settle. Anyone familiar with this product will realize that the power knob (all the way to the left) is the feature that takes the most abuse: It is a double function devise which powers up the preamp on when turned clockwise, and mutes the outputs when turned counterclockwise. The user must apply a greater deal of force to this knob than to the volume and balance knobs. I thought of carefully using Krazy Glue, JB Weld, or any similar product, but I found this resource and decided to wait and see if someone out there has a better suggestion. As many of you may know, Kliptch has killed the Aragon brand, so I can't really pick this bone with them. Thanks in advance for any advice you may come up with!
  • 54 Answers
Take the screw to hardware store and get an allen set screw then use an allen wrench to tighten. BIG RED 32
Posted on Apr 12, 2007
Take the scew out and take it to a hardware store to get an allen set screw put that in and tighten with allen wrench. BIG RED
Need knobs for ge gas range WB03T10295. All broke within six months after getting stove. All I can find are in the $30 range each which is obsurd. Any suggestions?
hey kim wassup? i m curious about how you managed to break all knobs so soon!! pl z handle it carefully, and try entering in the kitchen leaving all your frustration in bedroom.
so that in future you don't have to spend on same. ok? cheers!!
Nov 03, 2013 | GE KNOB GAS VALVE CH - WB03T10295
6 yrs old,tubes replaced by 1st owner,perfect for first 8 months,then seems volume diminished, and now distorts when i play hard,playing soft no problem but when i strum hard it distorts
Sounds very much like low emission in the output tubes. Do you know if they were replaced with brand new or used ones? Very possibly the replacements, if they were brand new, are Chinese sourced, and sadly their quality is very low and the lifetime short. Russian Sovtek tubes are much better quality and worth paying more for. It's also important to replace output tubes in pairs, and matched pairs if possible. If the tubes age at different rates, the result is signal distortion, getting progressively worse as the valves age further, although seldom bad enough to be really objectionable - unless one of the tubes has pretty much died altogether while the other one is still performing reasonably well - in that case the symptom is pretty much exactly what you are describing.... :o)
Aug 23, 2013 | Traynor Ycv80 Custom Valve 4x10 Combo Amp...
Dodge grand Caravan 1995 has been acting up with erratic heating since last month.
Could possibly need a new thermostat, the thermostat opens and closes depending on the heat of the coolant. maybe also check your heating core. as well as the quality of you coolant.
Jan 03, 2013 | 1995 Dodge Grand Caravan
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
My right ear bud cuts out every time I move my head. I've only had this pair about six months.
It shows that there is a loose connection.
Take the item back to place of purchase and get a replacement. It should be under warranty.
Take care!
damnor01
May 28, 2011 | Bose in-ear headphones - Black with...
Water is getting to the k-cup but does not come out unless I take the cup out and turn it around and puncture a second time. clear water runs through with no problem
Hi, W/D here.
Take an ordinary paper clip, and straighten it into an "L", with about 1" on the short side. With the Keurig opened as it would be for inserting a K-cup, locate the upper and lower puncture needles. Take the paper clip and use it to pass into the hollow needles to free up any debris that may have collected in the needles. Be careful, as the needle tips are very sharp. Do the lower needle as well. This should improve the quality of your brew.
Another thing that will help is to de-scale the machine with white vinegar. This is done by emptying the reservoir, and re-filling about half way with white vinegar. Then, brew two cups, which will draw the vinegar into the inner pot. Let the vinegar sit in the machine for several hours, and then empty the reservoir. Refill with clean water, and flush the water through the machine, one cup at a time, until no traces of the vinegar can be detected. This will keep your machine brewing at it's peak performance. Most folks perform this cleaning every six months or so, but you really need to do it according to the quality of your water, that is, use six months as a maximum, and more often if necessary.
Hope this gets your coffee back to just right. I KNOW how important that is!
Best regards, --W/D--
Jan 27, 2011 | Keurig B100 Coffee Maker
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
Did I kill my NT1A Condenser Microphone?
This mic has a pre-ampcircuit inside. It sounds like that preamp has a defective stage. What you are hearing is distortion. This is not something that can be repaired locally. This mic should be sent to the manufacturer for repair.
Dan
Mar 10, 2009 | Rode NT1A Professional Microphone
Initializing and nothing further
http://www.transcendusa.com/Support/DLCenter/index.asp
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Nov 10, 2007 | Transcend T.sonic 610 MP3 Player
Aragon 28K MKII 2-Channel Amplifier Logo
176 people viewed this question
Top Aragon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Aragon Audio Player and Recorder Expert? Answer questions, earn points and help others
