Computers & Internet Logo
Posted on Aug 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery plugged in but not charging - Lenovo Computers & Internet
Anonymous
Level 2:
  • Expert 177 Answers
  • Posted on Aug 25, 2012
Anonymous
Expert
Level 2:
Answers
177
Questions
0
Helped
38426
Points
426
If the notebook battery is not charging or the notebook does not indicate that the battery is charging, it's looks like that the battery is working, but its power management software may have a problem. You will need to uninstall and reinstall the power management software by using the Device Manager.
1.go to device manager
Right click on my computer->select Properties->click the Hardware tab->click device manager
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes
2answers
Dell n5010 not chargering
Hi Anonymous,
Request you to try following the below steps which might help:
    (1)Check if the AC Adaptor gets detected in BIOS (F2 at startup).
    (2)Check on the status bar for any messages like "Plugged in charging", "Not connected", etc.
    (3)Try using a known good AC Adaptor and check if that helps.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Battery gets to 8% or so, I plug it in, it says it's charging but warning keeps flashing, screen dims off and on and then it shuts off. Charges fine when it's off. Seemed to work fine before.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
My laptop will not charge it will stay running while plugged in. It says plugged in not charging
My dell vostro a860, when i plugged adapter its showing me plugged in not charging and continuously battery is not charging.
1helpful
Problem in charging of dell inspiron 1525...on plugged in power it shows plugged in but not charging.. please give me the solution related to charging of the laptop..
If the charging LED is on but the battery is not charging then the battery may be worn out.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
