Question about Casio Cassiopeia E-200 Pocket PC
Connect Cassiopeia E200 I to internet through cradle
Hi, I would like to know if it's possible connect my pda to my pc through cradle and share the broadband to update it?? No cf cards are available right now and everytime I try with a new connection it says: trhough Hayes compatible on com 1 then ask me for number to call! In settings I found PPT1 NDISWAN Adapter...but I guess I need a card? Pls suggest me the easy way to solve and use the broadband on my pc...
Thx A Lot,
G. (Italy)
vega
  • 551 Answers
SOURCE: Cassiopeia E-125 & Nokia 7650
You will need 2 things. Software to load on your E-125. The included Cd with your Nokia should have it. You will need a special cable to connect Nokia to E-125. I don't know where you will find it easily. There is a firm in Finland which makes all kinds of cables to connect different models of Cassiopeias to different models of mobile phones - essentially Siemens, Nokia & Ericsson. They run about US$ 50/= Last time I saw their listing it was 4 pages long. You might have to do some searching on the net or contact Casio for information. Hope this helps.
Posted on Sep 05, 2005
  • 903 Answers
SOURCE: Fail Power Off
You should try to use the PDA with the Power Supply cable directly,without the Cradle between it, Does the PDA works ?
Posted on Sep 08, 2005
sergioems
  • 32 Answers
you must get at least 3.7 bettwen + and -. have your cassiopeia being off some time? or just go that way sudently? cheers
Posted on Aug 25, 2007
  • 5 Answers
SOURCE: HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Posted on Jul 03, 2008
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Posted on Oct 01, 2008
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
INTERNET SETTIN
on your i-mate JAQ go to programs>internet sharing>connect.
prior to this pl make sure that your pda is connected to ur desktop via USB cable and it is synked with the desktop.
rgds,
May 10, 2008 | i-mate JAQ Pocket PC
Help!!!
The BE300 uses PC Connect and will not work with Activesync. All the original software and upgrades are available at www.be300.org
Dec 12, 2007 | Casio Cassiopeia BE-300 Pocket PC
Cassiopeia E-125
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
Casio e-100 questions......help!
Are you trying to install programs that run on your desktop to the pda? If that's the case, you cannot do it. The softwares for pda need to be written and compiled for your particular cpu and os.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
E200 Serial Port URGENT
You will not find any matching connector to connect the JK-744 host adapter for attaching to the 9 pin serial port on the pc. If you want full pinout details please contact me directly. Please do include some information on what you are trying to achieve. Maybe I can be of help in that department. I however have a feeling that trying any micro surgery on the JK-744 or trying any kind of non Casio adapter is likely to mess up the JK-744 device itself.
Sep 05, 2005 | Casio Cassiopeia E-200 Pocket PC
E-125 and Cradle/Internet access......
I don't know about the craddle - but I guess it should work too. I use a USB cable - and it works okay. You need to run MS ActiveSync (install v. 3.5 - it's better), and when you see a green circle in your taskbar, you can try and access Internet (your desktop should, of course, be connected to Internet).
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Open Questions:
Casio Cassiopeia E-200 Pocket PC Logo
66 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
